rubbing noise from rear drums before and after changing shoes......help!
Old Sep 17, 2005 | 09:18 PM
redpeppers's Avatar
Default rubbing noise from rear drums before and after changing shoes......help!
A wierd noise came to my rear drum recently and i assumed it was my brake shoes rubbing so i changed them and had the drums turned. After installing the shoes the noise is still there. It is there when i hit the brakes or when i use the ebrake but only when i am rolling (i can only hear it at slow speed, like when i am slowing down) I did not use any oil or grease when i did the brake swap. I am confused what the prob is....can any help
Old Sep 18, 2005 | 09:54 AM
EK45VTi's Avatar
Default Re: rubbing noise from rear drums before and after changing shoes......help! (redpeppers)
Clean the drums...
Take off the drums, get some sandpaper and sand the braking surface of the drum... then take some clean cloth and wipe the dust from the drums and then reinstall them... I am 99.9999% sure the noise will go away...
I had the same problem, and I solved it that way...
Old Sep 18, 2005 | 10:31 AM
sicones's Avatar
Default Re: rubbing noise from rear drums before and after changing shoes......help! (KKVTi)
brake cleaner
Old Sep 19, 2005 | 08:35 AM
redpeppers's Avatar
Default Re: rubbing noise from rear drums before and after changing shoes......help! (sicones)
ok ill try that
manatee
14
Jul 27, 2012 05:09 AM
GAngulo7
Honda Civic (2001 - 2005)
Jan 26, 2010 08:17 PM
user 6297290
Feb 23, 2006 05:34 AM
redpeppers
Sep 13, 2005 09:21 PM
redpeppers
16
Aug 25, 2005 07:46 PM
