Will 88-91 struts fit 92-95 civics?
Old Sep 17, 2005 | 06:13 PM
Azneita's Avatar
Default Will 88-91 struts fit 92-95 civics?
are they direct swaps?
Old Sep 17, 2005 | 07:46 PM
msmotorsports's Avatar
Default Re: Will 88-91 struts fit 92-95 civics? (Azneita)
Not a direct fit
Old Sep 18, 2005 | 08:35 AM
IMALLSLO's Avatar
the strut fork is smaller in diameter on the 88-91.
Old Sep 18, 2005 | 09:26 AM
projectTeG's Avatar
i think all you need to use the 88-91 front drop fork
Old Sep 19, 2005 | 12:11 PM
tgreaves's Avatar
Default Re: (projectTeG)
The rears are the same.. Just use the 88-91 forks on the front and your good..
I will tell you that the front of the 92-95 will sit lower when using the 88-91 forks but its not too bad..
Old Sep 21, 2005 | 09:42 AM
hxtasy's Avatar
Default Re: (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">The rears are the same.. Just use the 88-91 forks on the front and your good..
I will tell you that the front of the 92-95 will sit lower when using the 88-91 forks but its not too bad..</TD></TR></TABLE>
hey thanks for you help guys.
im not completly sure on which part I need though.
do i need # 12,13 the acutal fork off the EF civic or the Lowwer Arm #6,7
My '90 b16 hatch is totaled and i just bought a 94 hatch.
i really want to keep my KYB struts and Tein springs becuase they are practically new and I wouldnt get that much for them.
also, my springs are like 1.5" drop, how much lower will the EF parts make it?
and will integra control arms or forks work?
Much appreciated!
~pennhatch
(didnt remember pw for this sn last time) Azneita=pennhatch
Old Sep 21, 2005 | 09:52 AM
tgreaves's Avatar
Default Re: (pennhatch)
You just need the 15-16 forks and thats it.. im not sure about the lowering, Put it on and see if it works for you..
Old Sep 21, 2005 | 10:14 AM
hxtasy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">You just need the 15-16 forks and thats it.. im not sure about the lowering, Put it on and see if it works for you..</TD></TR></TABLE>
you mean 12 and 13 or right?
Old Sep 21, 2005 | 10:27 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennhatch &raquo;</TD></TR><TR><TD CLASS="quote">
you mean 12 and 13 or right?</TD></TR></TABLE>
Opps.. Yep, 12/13 is all you need.. The rears are exactly the same and you can use the 88-91 LCA's if you want..
Old Sep 21, 2005 | 07:01 PM
hxtasy's Avatar
I already had the rear LCA from a 92-95 civic on my EF, they were the megan racing ones.
i belive the EG's are 1/16 inch longer than the EF LCA's, adding a little bit of camber.
well thanks for all the help guys hopefully no bolts break while im swapping suspension!
patrickstar
Jan 10, 2009 09:30 AM
TOMSBLUEHONDA23
May 4, 2005 07:14 PM
