my tig weld pipes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CashmoneyUKR »</TD></TR><TR><TD CLASS="quote">3" seems way to big. Unless your running 1000whp it seems to big.. Maybe for cold side... Or maybe im wrong</TD></TR></TABLE>
the turbo, the front mount and the intake is 3 inch. and thats wat he wanted. n trust me he is making huge power. like mid 9s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by more-fire-racing »</TD></TR><TR><TD CLASS="quote">
Thats cool. I'd use then 2.5 for the hotside..... But sick car
</TD></TR></TABLE>Thats cool. I'd use then 2.5 for the hotside..... But sick car
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
you mean he is planning on running mid 9s?
</TD></TR></TABLE>you mean he is planning on running mid 9s?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">I think mid 9's means ~950hp. In that case it might warrant the need for 3" pipes.</TD></TR></TABLE>
Maybe so, that's still alot.
Also, why the choice of stainless?
950hp is definatley not needed to run nines in a fwd honda..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruceleeroy »</TD></TR><TR><TD CLASS="quote">950hp is definatley not needed to run nines in a fwd honda..</TD></TR></TABLE>He said the phrase "mid 9's" probably meant 950hp, not 9.5 seconds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkeith »</TD></TR><TR><TD CLASS="quote">Maybe so, that's still alot.
Also, why the choice of stainless?</TD></TR></TABLE>
yeah, why stainless? wouldnt alu. help since it is lighter
aluminum isn't better than stainless because it's lighter.
sure that's a definate plus, but when you're looking at the weight of charge piping it's not really that big of an issue.
you choose aluminum because it dissipates heat faster. stainless retains heat for a lot longer than mild steel even.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kookz »</TD></TR><TR><TD CLASS="quote">He said the phrase "mid 9's" probably meant 950hp, not 9.5 seconds.</TD></TR></TABLE>
i see now thanks..
i see now thanks..
