lowering a 600RR
Old Sep 17, 2005 | 05:30 PM
CDN Yellow ITR's Avatar
Default lowering a 600RR
whats going on guys??
well i plan on buying a honda 600RR in the sping time and i was wondering if you could lower the bike 2-3 inchs with the factory coil, or do i have to buy a kit for it??
thank you in advance
-tony
Old Sep 17, 2005 | 05:34 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
Default Re: lowering a 600RR (CDN Yellow ITR)
There are a few ways to "lower" bikes. Why do you think you will need to lower yours?
Old Sep 17, 2005 | 05:39 PM
Default Re: lowering a 600RR (RebornGSR)
i'm 5'3 thats why hahaha
Old Sep 17, 2005 | 05:54 PM
01-0720's Avatar
well you can pull the forks threw the trees a little bit, then you can get dog bones for the rear or there called lowering links, that will get it pretty low
Old Sep 17, 2005 | 05:55 PM
Grumpy Old Man
You could shave the seat but that's pretty minimal on a 600rr.
5'3 isn't that small and I suggest you just learn how to hold the weight of the bike while on your right leg. Messing with the geometry of the bike(lowering) seriously effects handling in a negative way and should only be done as a last resort.
You might not notice the difference if you only plan to cruise around on the bike and never test its limits.
Old Sep 17, 2005 | 06:05 PM
Grumpy Old Man
Jason DiSalvo is 5'3 and he can flat foot:
Old Sep 17, 2005 | 06:41 PM
MSchu's Avatar
My Name is Nobody
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CDN Yellow ITR &raquo;</TD></TR><TR><TD CLASS="quote">i'm 5'3 thats why hahaha</TD></TR></TABLE>
easier and better to buy platform shoes!!! Iknowa few makers that make platforms for height challenged short *****
Old Sep 17, 2005 | 06:46 PM
EGlovr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RebornGSR &raquo;</TD></TR><TR><TD CLASS="quote">Jason DiSalvo is 5'3 and he can flat foot:</TD></TR></TABLE>
his heel is up!!!!
Old Sep 17, 2005 | 07:02 PM
redline201's Avatar
that looks uncomfotable as ****
buy an pre 06' R6 and shave the seat
Old Sep 17, 2005 | 07:09 PM
MSchu's Avatar
My Name is Nobody
Default Re: lowering a 600RR (redline201)
there's no reason to do anything, unless your really uncomfortable
Old Sep 17, 2005 | 07:24 PM
UTCiv's Avatar
On my ZX6R the adjustment was about 2.0" +/- on the stock coil. I have my rear spring set almost at the lowest range possible for comfort sake.
Honestly it feels much more stable in turns with this configuration mostly due to the ZX6R's front configuration of clipons below the triple clamp. I always thought the bike felt very twitchy with the rear spring set where it was when I bought the bike.
I wouldn't mess with the front forks if you do not have to as they will not benefit seat height as much as rear shock.
I would agree with sticking to the limits of the stock suspension range if you plan to use the bike as it was designed. Once you have maxed out the rear shock height, there are options of narrowing the seat, shaving height off of it, and just compensating at a stop by shifting on the seat.
But whatever, do what it takes to be comfortable. I have always thought (Keith Code would agree, and I'm sure he analyzed this first) that distractions and discomfort take up a lot of your minds ability to concentrate on much more important decisions on the road.
Modified by UTCiv at 1:26 PM 9/18/2005
Old Sep 18, 2005 | 09:21 AM
Urban Camo's Avatar
Default Re: lowering a 600RR (UTCiv)
would it be the same as the 600rr to the F4i? cause i would like to lower my F4i
Old Sep 18, 2005 | 08:43 PM
WhoisDan's Avatar
Default Re: lowering a 600RR (Urban Camo)
Yeah, lowering a bike effects its ability to handle like it should. I would suggest leaning on your right foot.
Old Sep 18, 2005 | 08:53 PM
backlash's Avatar
Default Re: lowering a 600RR (WhoisDan)
Yeah, don't lower the bike, just pull the "one cheek sneak" move, I'm about 5'5-5'6 and I do the one cheek thing on my RC.
Old Sep 18, 2005 | 08:56 PM
Nameless RB26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhoisDan &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, lowering a bike effects its ability to handle like it should. I would suggest leaning on your right foot.</TD></TR></TABLE>
That looks incredibly stupid. I don't know many people who want to look goofy at every traffic light.
If you aren't racing it then lower it a bit. If you race, bring it back up.
That's a simple solution.
I'm 5'6 and I can touch toes to the middle of my feet on most 600/1000's.
Old Sep 18, 2005 | 09:20 PM
Muffler Bearing's Avatar
I will never complain about being 6'3" ever again.
Old Sep 18, 2005 | 09:35 PM
Kyles ej1's Avatar
Default Re: (Muffler Bearing)
im like perfect height for my cousins r1---5'10"
Old Sep 18, 2005 | 09:45 PM
Jay_Sensing's Avatar
You can snag a link to lower it with off of http://www.myrtlewestcycle.com. then just drop the forks through the trees about an inch and you will be golden.
Old Sep 18, 2005 | 09:48 PM
vox's Avatar
vox
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backlash &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, don't lower the bike, just pull the "one cheek sneak" move, I'm about 5'5-5'6 and I do the one cheek thing on my RC. </TD></TR></TABLE>
yea, i do this all the time...ive got a 600rr and im about 5'6 too and most of the time when i am at a stoplight, i usually only have one foot touching the ground, which is plenty. i havent done much by the way of adjusting the stock suspension cause i think its fine the way it is.
Old Sep 19, 2005 | 07:04 AM
Newkdog's Avatar
I miss Andrea.
I don't know what to tell you man!
Old Sep 19, 2005 | 07:27 AM
Mag00n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CDN Yellow ITR &raquo;</TD></TR><TR><TD CLASS="quote">whats going on guys??
-tony</TD></TR></TABLE>
Dont do it, aight?
Old Sep 19, 2005 | 08:01 AM
ProjectF4's Avatar
Default Re: lowering a 600RR (Mag00n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mag00n &raquo;</TD></TR><TR><TD CLASS="quote">Dont do it, aight?</TD></TR></TABLE>
yeah, listen to the goon
unless of course you live in the south, where everything is dropped and streched
Old Sep 19, 2005 | 08:03 AM
W.O.P.'s Avatar
at the track, ive seen people use rachet style tie downs to pull donw the fron end. i dont know how well this held up on the track though.
Old Sep 20, 2005 | 05:27 PM
Snail EK's Avatar
Old Sep 20, 2005 | 06:29 PM
backlash's Avatar
Default Re: lowering a 600RR (Snail EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snail EK &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
WTF does this reply mean?
