Look what happened to my rear sway bar.
Old Sep 17, 2005 | 03:49 PM
RAK's Avatar
RAK
Default Look what happened to my rear sway bar.
While driving, I was hearing a noise in the rear so when I went to check it out, this is what I found. I was using an ST swaybar when this happened. Anyone experience this problem? What's the best solution? I'm figuring I'll just weld the bracket back on.
The last pic shows what the subframe is supposed to look like. Any help would be appreciated!
Old Sep 17, 2005 | 04:21 PM
Yield's Avatar
Yah it's happened to several people with beefier rear sways. I've seen people either weld just the bracket back or others have welded a new plate in there to make it even stronger.
Old Sep 17, 2005 | 04:33 PM
HxClude's Avatar
Default Re: (Yield)
order a set of rear swaybar brackets from Neuspeeds (call them up -part isn't listed on their website by itself, only with the rear sway) and you're good to go - no custom fab necessary.
The Neuspeed mounts make the stock ones look like a joke
Old Sep 17, 2005 | 08:01 PM
Honda318dx's Avatar
Default Re: (HxClude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HxClude &raquo;</TD></TR><TR><TD CLASS="quote">order a set of rear swaybar brackets from Neuspeeds (call them up -part isn't listed on their website by itself, only with the rear sway) and you're good to go - no custom fab necessary.
The Neuspeed mounts make the stock ones look like a joke </TD></TR></TABLE>
But the mounts didn't break, the chassis did!
You MUST get stiffer springs on the back, what is your current suspension setup?
Old Sep 17, 2005 | 08:03 PM
Matgallis's Avatar
Default Re: (Honda318dx)
looks pretty rusted..
Old Sep 17, 2005 | 08:33 PM
lilryan's Avatar
Default Re: (Matgallis)
looks like rust had a part to play in the downfall of that mount.
Old Sep 18, 2005 | 06:41 AM
RAK's Avatar
RAK
Default Re: (lilryan)
I have Eibach Sportlines w/ Tokico Illuminas. Also, this car was from Pennsylvania, so I know rust helped with the failure.
Old Sep 18, 2005 | 07:20 AM
HxClude's Avatar
I should have looked more closely . . . wow . . . I've seen the brackets give but not the chassis
Old Sep 18, 2005 | 07:38 AM
mkazm83's Avatar
How thick is your rear bar?
Old Sep 18, 2005 | 09:16 AM
LudeyKrus's Avatar
Default Re: (Yield)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yield &raquo;</TD></TR><TR><TD CLASS="quote">Yah it's happened to several people with beefier rear sways. I've seen people either weld just the bracket back or others have welded a new plate in there to make it even stronger.</TD></TR></TABLE>
x2
You should add a bar/plate to reinforce the area instead of just welding it all back together.
Old Sep 18, 2005 | 09:59 AM
RAK's Avatar
RAK
Default Re: (LudeyKrus)
I believe it's 1" in diameter. It was on the car when I bought it. I'll probably just weld the bracket to a steel plate and then the plate to the chassis.
Old Sep 18, 2005 | 03:21 PM
Hawkze_2.3's Avatar
Default Re: Look what happened to my rear sway bar. (RAK)
Progress sells their rear bar with a custom 3-bolt mount included for both sides. It's waaayyy beefier than the stock mount.
With what you have there I would clean off the rust the best you can and have it welded back on stronger than it came stock....
Old Sep 18, 2005 | 09:00 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: Look what happened to my rear sway bar. (Hawkze_2.3)
Ouch...
Old Sep 18, 2005 | 09:17 PM
red92si's Avatar
Its a well known issue with the older huge Neuspeed bars. Sorry to see it happen with your setup. Go with the Progress or Neuspeed mounts and you'll be good to go.
Old Sep 22, 2005 | 12:22 AM
db8xc1x39
Guest
Posts: n/a
Default Re: (red92si)
fucc! major rust issue there that caused that..buy the kit for your brackets and youll be good...and weld if all else fails..good luck with that
Old Sep 24, 2005 | 07:34 PM
cruzin89lude's Avatar
holy crap
super jdm yo
Jun 2, 2009 05:31 PM
auto addict
Jul 6, 2008 12:47 PM
DarkBB4
Jun 6, 2006 02:56 PM
turbotime
Apr 18, 2005 10:13 PM
ADN_pt
59
Jan 19, 2005 05:30 PM
