idling weird: going up and down on its own.
Old Sep 17, 2005 | 03:38 PM
kizo's Avatar
Default idling weird: going up and down on its own. some one please help!!!!!
Hi, i have a honda civic hatch 1990 and its fluctuating up and down, i wanted to know if anyone can help me please becasue everyone thinks i'm trying to challenge them to a race when i'm just trying to get to work and back home. and the noise is freaking annoying....someone please help me.....
Modified by kizo at 5:05 PM 9/17/2005
Old Sep 17, 2005 | 04:31 PM
kizo's Avatar
Default Re: idling weird: going up and down on its own. some one please help!!!!! (kizo)
okay, i guess no one knows whats wrong with my car since no one is responding..... i need help ASAP!!!!
Old Sep 17, 2005 | 07:35 PM
SockEG's Avatar
check your coolant level..sounds crazy, but can cause your IAC valve to act funny causing a weird idle, something like 800-1500 back and forth.
Old Sep 17, 2005 | 11:35 PM
sir2sol's Avatar
Default Re: idling weird: going up and down on its own. some one please help!!!!! (SockEG)
diffinately sounds like your iacv, take it off and clean the screen real good. if that doesn't work check all of your vaccum lines to make sure there's no leaks with them. also might want to check your ignitor as well.
Old Sep 19, 2005 | 05:43 AM
JimBlake's Avatar
Default Re: idling weird: going up and down on its own. some one please help!!!!! (sir2sol)
Also check your FITV, it can cause this too. And vacuum leaks.
Old Sep 19, 2005 | 08:43 PM
sicsixone's Avatar
Default Re: idling weird: going up and down on its own. some one please help!!!!! (JimBlake)
on the front of your throttle body "middle, top" there is a brass screw with a screw driver slot.this is your idle screw.before removing it make sure you use a scribe and clean the slot out so you do not strip the slot.then take the air adjusting screw out and clean all the carbon off of it.and then put the screw back in and readjust your idle.
Old Sep 19, 2005 | 09:35 PM
honda_power69's Avatar
Default Re: idling weird: going up and down on its own. some one please help!!!!! (jonsswapshop)
Heres a link explaining how to check for FITV (Fast Idle Thermo Valve) problems. Always good to bump that thread if you find it useful, for others' sake when they search.
https://honda-tech.com/zerothread?id=1003988
**Note that this article uses pictures from a b16a motor, but the basic concept of what needs to be done is pretty simple to grasp for people who are even a little mechanically inclined.**
Hope this helps you.
Old Sep 19, 2005 | 09:41 PM
sicsixone's Avatar
Default Re: idling weird: going up and down on its own. some one please help!!!!! (honda_power69)
i dont think that 90 1.6 has fitv i know that is a comin problem with b16 .the big white screw loosens up.
Old Sep 19, 2005 | 09:59 PM
Above poster could be correct, I'm not sure personally. But wouldn't take 30 seconds to pop the hood and get a visual answer...all I'm saying is it wouldnt hurt to check. Otherwise, 90% of every honda/acura idle problem I've come across in my days wrenching has been vacuum related. Be it from FITV problems, cracked/dry rotted vacuum hoses, gasket leaks, etc. Just go over every vacuum line you see, make sure theres no obvious breaks/cracks/or completely missing lines and get back to us.
Feedback from the original poster is the only way we can know if we've helped you, and what has or hasn't worked for you. So get back to us
Old Sep 19, 2005 | 10:01 PM
HondaTom's Avatar
Is it the factory engine in the car?
j0keefe21
Engine Management and Tuning
Aug 7, 2008 12:08 PM
busman
Oct 5, 2003 07:52 PM
joestud
Sep 30, 2002 03:59 PM
digitalspice
Feb 20, 2002 02:35 PM
