Rear Main Seal
Old Sep 17, 2005 | 03:18 PM
Ricey McRicerton's Avatar
Default Rear Main Seal
I've got my clutch, flywheel and tranny all out, so I'm replacing my rear main seal.
Is there some kind of trick to getting this thing out? I'm stumped.
Old Sep 17, 2005 | 03:53 PM
SkRiBLaH's Avatar
Default Re: Rear Main Seal (Ricey McRicerton)
undo the tiny 10's
and pop it off.
it is held on by 2 dowels that line it up so you might need to give it the flathead flick.
Old Sep 17, 2005 | 04:48 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Rear Main Seal (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">undo the tiny 10's
and pop it off.
it is held on by 2 dowels that line it up so you might need to give it the flathead flick.</TD></TR></TABLE>
yeah, and you have to remove the oil pan also.
Here's what you do-
pry it out with a small flat head screwdriver, clean out the area, and evenly press in the new one- tap around the outside with a hammer...LIGHTLY. It will go right in
Old Sep 17, 2005 | 05:33 PM
Luserkid's Avatar
Default Re: Rear Main Seal (Evs-One)
Just work with it. Its a bitch at first but after time it gets easier (obviously) But i had a bitch of a time at first too.
Old Sep 17, 2005 | 05:45 PM
Yeah, I just found out from Dustin that I have to remove the oil pan. I'm just not willing to work on it any more tonight.
Old Sep 17, 2005 | 06:42 PM
Stripped Honda's Avatar
99-0104
i change these things all the time at work and i never remove the oil pan .... just jently put a screwdriver between the crank and the seal and pry outward .. do this in 3-4 different places and the seal will come out ... before installing the new seal lubercate the inside of the seal with grease and carefully re install the seal . it is very easy and takes 5 minutes .. dont do the remove the oil pan trick it is a waste of time ..
Old Sep 17, 2005 | 06:47 PM
Kendall's Avatar
It's usually Hondabonded on there pretty good so expect to need some measurable quantity of "finesse" to remove it. Don't forget to clean the mating surface on the block before putting the new one on.
Old Sep 17, 2005 | 06:48 PM
PLAN:B's Avatar
Default Re: Rear Main Seal (Stripped Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Honda &raquo;</TD></TR><TR><TD CLASS="quote">i change these things all the time at work and i never remove the oil pan .... just jently put a screwdriver between the crank and the seal and pry outward .. do this in 3-4 different places and the seal will come out ... before installing the new seal lubercate the inside of the seal with grease and carefully re install the seal . it is very easy and takes 5 minutes .. dont do the remove the oil pan trick it is a waste of time .. </TD></TR></TABLE>
this is a much easier way to do it...just be careful not to damage the crank. even little scratches on the crank by the seal can = small oil leak
Old Sep 17, 2005 | 09:53 PM
99-0104
Default Re: Rear Main Seal (PLANBmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PLANBmotorsports &raquo;</TD></TR><TR><TD CLASS="quote">
this is a much easier way to do it...just be careful not to damage the crank. even little scratches on the crank by the seal can = small oil leak</TD></TR></TABLE>
as long as your carefull you will never scratch the crank surface and yes it is a better way to do it ... the honda-bond on that plate will never leak so there is no reason to take it off .. i have actually seen people cause more harm by doing it this way ... when they pry on the plate to remove it they crack it and later have a oil leak that they end up pulling the tranny again for ... so either way is good but just changing the seal is a better way to do it
grampswrx
Jan 4, 2016 09:32 AM
rogue420
14
Jul 18, 2010 05:44 PM
clawhammer
Honda Civic (2001 - 2005)
Jul 16, 2010 08:04 AM
JDMPower98cp
Jan 2, 2006 12:11 AM
Do_Ster
Jan 14, 2005 08:23 AM
