who decided JDM ITR's have 2.5" exhaust?
can someone please post a pic, cuz ive yet to see one with a 2.5" exhaust..
why would the aftermarket ones be 60mm if they cam larger than that stock..
also the JDM R cat was no more than 55mm at the exit.
any ideas?
pictures are worth 1000 words.
any ideas?
You are correct that JDM Integra Type R's do not come with a 2.5" catback stock. However, I have yet to see anyone on this board claim otherwise. Who is it that you are directing that assumption to?
I know b18c1_powered_si had some JDM ITR 2.5" mid pipes for sale for a while.
Proven by the seller?
thanks guys.. I really want a larger than 60mm exhaust.. and i hate to see people believe that they are getting that with a stock JDM exhaust..
I thought i might be mistaken.. but i have seen some JDM r exhausts and they werent anything special.. someone should make an affordable 2.5" quiet exhaust.
I actually have a JDM ITR b-pipe. It is larger than the USDM one. I never did measure it though. I lined a USDM, a JDM, and a Mugen side by side. The JDM fell right in the middle. Not quite as large as a Mugen but definitely larger than a USDM. The JDM is better in quality but not on par with Mugen.
Ofcourse the JDM Pipe is not 2.5" 60mm is not 2.5" that would be around 64mm JDM Header has a 65mm Outer diameter on the collector. Figure the thickness of the steel and it's right around 60mm inner diameter.
onyx00
Aug 11, 2001 07:32 AM
