Removing back seats
How do I remove the back seats in my DC2? I couldn't seem to find where the mounting points are that I need to unbolt. I'm sure someone has done this before.
If your looking to take them out for weight purposes i dont think its worth it since they dont weight much.
But if your taking them to have that "gutted" look or to avoid having rear passengers, then go for it.
actually....there's no nuts. There should be one 10mm bolt and that's it. Once you've removed the carpet backing on the top portion of the rear seats, you just "unhook" them from the center piece and pull them out. After that, you'll see the 10mm bolt that attaches the bottom portion to the chassis. Remove that then swing the back portion of the bottom up and pull them out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chewie »</TD></TR><TR><TD CLASS="quote">all back seat all together weights in like 1-2 lbs at most i think. didnt use a scale, just went out to the garage and picked them up. effect is minimal.</TD></TR></TABLE>
damn, if they only weigh 1-2 lbs then forget it. i was, however, thinking about taking out my spare tire. but i dunno if thats really worth it either. don't wanna be assed out when i get a flat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numotive »</TD></TR><TR><TD CLASS="quote">
however, thinking about taking out my spare tire. but i dunno if thats really worth it either. don't wanna be assed out when i get a flat.</TD></TR></TABLE>
Yup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naruto »</TD></TR><TR><TD CLASS="quote">actually....there's no nuts. There should be one 10mm bolt and that's it. Once you've removed the carpet backing on the top portion of the rear seats, you just "unhook" them from the center piece and pull them out. After that, you'll see the 10mm bolt that attaches the bottom portion to the chassis. Remove that then swing the back portion of the bottom up and pull them out. </TD></TR></TABLE>
Thats all folks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numotive »</TD></TR><TR><TD CLASS="quote">yeah some pics would be great </TD></TR></TABLE>
i'm at work right now, but let me sneak out of here in about 5 minutes to take some.
Yup.
Thats all folks.
really only 1-2 pounds? for everything? rear cushion, backrest, and carpet?
when i took mine out it felt it weight more than 1-2 pounds or im really weak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. One Lane »</TD></TR><TR><TD CLASS="quote">
when i took mine out it felt it weight more than 1-2 pounds or im really weak </TD></TR></TABLE>
I'm not sure about 1-2 pounds, but its pretty light.
PM'ed you.
</TD></TR></TABLE>PM'ed you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5 Speed Dc2 »</TD></TR><TR><TD CLASS="quote">
i stand corrected, i just weighted the upper portion of the back seats. 10lbs each of the upper seats. had too much crap on the bottom so i didnt weight that, but the bottom part is definitely lighter because its basicly all foam instead of the top with metal backings.
mine are the leather ones btw, dont know if that makes a difference.
You cant just unhook them from the centre, theres those little clips on each side where you have to remove first. Doing that will allow you to shift the seat to the left/right a bit from where you then can unhook the seat
came across this thread, shows weights of parts a person removed from dc2
http://www.team-integra.net/fo...ion=2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sifu »</TD></TR><TR><TD CLASS="quote">You cant just unhook them from the centre, theres those little clips on each side where you have to remove first. Doing that will allow you to shift the seat to the left/right a bit from where you then can unhook the seat
I know....but I from experience, whenever I removed my rears, it was easier if I pushed the top portion to the side and got it out that way. But...either way it works.
</TD></TR></TABLE>I know....but I from experience, whenever I removed my rears, it was easier if I pushed the top portion to the side and got it out that way. But...either way it works.
I know....but I from experience, whenever I removed my rears, it was easier if I pushed the top portion to the side and got it out that way. But...either way it works. </TD></TR></TABLE>
Yeah but in order to be able to push them to the sides you need to remove those clips on the sides, unless you dont have them in your car??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donutz »</TD></TR><TR><TD CLASS="quote"> Clicky</TD></TR></TABLE>
also thanks to 5 Speed Dc2 for e-mailing me pics!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sifu »</TD></TR><TR><TD CLASS="quote">Yeah but in order to be able to push them to the sides you need to remove those clips on the sides, unless you dont have them in your car??
I did have em....now that you mention it.....I forgot to put them back in way back in the day when I first converted the interior from tan to black
</TD></TR></TABLE>I did have em....now that you mention it.....I forgot to put them back in way back in the day when I first converted the interior from tan to black
