do prelude crossmembers....
Old Sep 17, 2005 | 01:04 PM
dropped like its hot's Avatar
Default do prelude crossmembers....
for the older like 94's do the front crossmembers bolt on or is it welded?
Old Sep 17, 2005 | 01:21 PM
98vtec's Avatar
moderator emeritus
Default Re: do prelude crossmembers.... (dropped like its hot)
bolted (atleast it should be)
Old Sep 17, 2005 | 02:01 PM
Default Re: do prelude crossmembers.... (98vtec)
so how sure are you
Old Sep 17, 2005 | 02:08 PM
98vtec's Avatar
moderator emeritus
99% sure because the 5th gen is bolted. I would assume that the 4th gen is the same way.
Old Sep 17, 2005 | 04:25 PM
yOnKiNaToR's Avatar
bolted. 100% positive. (i've taken all of the suspension out of my car and know it well)
it would be kind of stupid to weld it in. especially if it was bent and you needed to replace it.
Old Sep 18, 2005 | 02:40 AM
rival12's Avatar
i just bent mine on my 94 accord, if it was not bolted i would be throwing my car away, after pulling the motor
Old Sep 18, 2005 | 09:07 AM
LudeyKrus's Avatar
Its' bolted in. You remove the center brace running to the rear crossmember, detach the suspension pieces from each side of it, and drop it down. Oh yeah, you got the front motor mount on top as well.
I believe you could replace it with an aftermarket tubular unit, if you wish.
Old Sep 22, 2005 | 08:52 PM
rival12's Avatar
Default Re: (LudeyKrus)
your talking about the subframe yes?
racins4
May 7, 2020 07:56 PM
thePHIG
Jan 8, 2007 08:00 PM
black_sh
May 8, 2003 07:54 PM
p10hlm
Dec 2, 2002 07:11 AM
Mr. H22A
Apr 24, 2002 05:23 PM
