Plastic Rear tail gates EG6
Old Sep 17, 2005 | 10:58 AM
Chris_Gee's Avatar
Default Plastic Rear tail gates EG6
Hi all
i did try a search but i could only find info about CF ones.
Im after the rear tail gate for a EG6 hatch, but im not keen on the cf one as i think its a bit too ott CF, but i want the weight saving, so im trying to find a plastic FRP one.
I know J's racing do one buts its like £280 (about $500) whcih is stupid as you can get CF ones for like $300-400...
Im planning on painting it, and it just seams a waste to get a cf one just to spray over it, do you guys know of anyhwere that makes cheaper plastic ones?
Or should i stop moaning and just get a cheap cf and spray it
Many thanks
Chris_Gee
Old Sep 17, 2005 | 11:05 AM
e9's Avatar
e9
Default Re: Plastic Rear tail gates EG6 (Chris_Gee)
all I can say is spend your money elsewhere
One of the big brake kits fastbrakes offers is 20lbs lighter for just the font and you'll stop alot better and since it's a drop in rotating weight it's alot better for acceleration and handling as well.
Modified by e9 at 7:03 PM 9/20/2005
Old Sep 17, 2005 | 11:06 AM
JDM-EJ1's Avatar
I've never heard of plastic hoods/tail gates. You could see about getting one made of fiberglass.
Old Sep 20, 2005 | 02:50 AM
Chris_Gee's Avatar
Default Re: Plastic Rear tail gates EG6 (e9)
I can see you point, and i will be looking into that as well, as im running nsx calipers on the front and the disks weight a ton lol
However i wanted to upgrade the tail gate to a jap rear number plate, and thought i might as well save some weight here while im at it.
Thanks
Chris_Gee
Old Sep 20, 2005 | 04:33 AM
v4lu3s's Avatar
RTFM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e9 &raquo;</TD></TR><TR><TD CLASS="quote">all I can say is spend your money elsewhere
One of the big brake kits fastbrakes offers is 200lbs lighter for just the font and you'll stop alot better and since it's a drop in rotating weight it's alot better for acceleration and handling as well.</TD></TR></TABLE>
how did they get the brakes to be negative weights? is that even possible in the realm of physics to hav negative weight?
bad-monkey
Honda Motorcycles
36
Jun 5, 2007 06:31 PM
civicshowracing65
Welding / Fabrication
Oct 16, 2005 03:41 AM
4DRPIMPIN
Jun 17, 2003 06:56 AM
