MACHINING SPECS(MINIMAL RUN OUT)ON A D15B2 HEAD
Old Sep 17, 2005 | 08:46 AM
Civiclized's Avatar
Default MACHINING SPECS(MINIMAL RUN OUT)ON A D15B2 HEAD
I need these freaking specs!!!
I have a project in the works and in stead of shaving the head or using the factory style replacement gasket, I want to use a shim-a thin peice of metal pressed out the same as the o.e. style gasket. It is .020"(twenty thousands thick) the o.e. style is .045" (forty five thousands thick).
Piont is, with out the minimal specs you can shave a head down to I can't find out weather or not the difference in the gasket will be to much and destroy my valve train!!!!!!!!!!!!
PLEASE POST.
Old Sep 17, 2005 | 11:33 AM
sporkcrx's Avatar
Default Re: MACHINING SPECS(MINIMAL RUN OUT)ON A D15B2 HEAD (Civiclized)
Well people mill their head .030" so you should be fine clearance wise. I don't know how well your shim will seal though.
Ϛikness_MoreϚik
Jul 11, 2009 09:40 PM
-Darren-
Jun 2, 2009 03:54 PM
TravisCadello
17
Apr 10, 2009 11:29 PM
da_33
Jan 11, 2007 11:12 AM
g5r
Jun 25, 2003 07:45 PM
