People who changed their clutch. DIY
Old Sep 16, 2005 | 07:08 PM
.water's Avatar
Default People who changed their clutch. DIY
in about few week iam plan to change the clutch. i saw my friend doing it, when he is taking off clutch the plate were spinning (when he is unbolting). so how to stop spinning?? is there a kit for that? or someone has to hold it.
Old Sep 16, 2005 | 09:51 PM
Dartanian's Avatar
Default Re: People who changed their clutch. DIY (JunkyDC2)
Honda offers a tool that screws into one of the tranny mounting bolt holes that will keep the flywheel from moving. I can't tell you how much it costs because I just had a buddy stick a screwdriver between the slots while I tightened everything up.
Old Sep 16, 2005 | 09:52 PM
98b18black's Avatar
Default Re: People who changed their clutch. DIY (Das Schmoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo &raquo;</TD></TR><TR><TD CLASS="quote">Honda offers a tool that screws into one of the tranny mounting bolt holes that will keep the flywheel from moving. I can't tell you how much it costs because I just had a buddy stick a screwdriver between the slots while I tightened everything up.</TD></TR></TABLE>
Same here
Old Sep 16, 2005 | 09:53 PM
kuja's Avatar
ah don't buy a tool.. jam that screwdriver in there and ur all set..
Old Sep 16, 2005 | 09:54 PM
thelate1's Avatar
Default Re: People who changed their clutch. DIY (98b18black)
ditto on the screwdriver. make sure you have a friend to help you remove tranny, it makes it so much easier.
Old Sep 16, 2005 | 09:56 PM
Kendall's Avatar
I usually just put a breaker bar on the crank pulley.
Old Sep 16, 2005 | 10:07 PM
gsr dood's Avatar
Default Re: (Kendall)
YOU NEED A FRIEND TRUST ME its really heavy puttin back the tranny and just jam a crow bar in there and it wont go anywhere
Old Sep 16, 2005 | 10:12 PM
Sifu's Avatar
Wouldnt jamming all these stuff in between the slots wreck the gear teeths??
Old Sep 16, 2005 | 10:48 PM
Kendall's Avatar
Default Re: (gsr dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr dood &raquo;</TD></TR><TR><TD CLASS="quote">YOU NEED A FRIEND TRUST ME its really heavy puttin back the tranny</TD></TR></TABLE>
I can't count the number of B-series clutches I've changed and I've never needed help from anyone doing it. Plus I'm a really lanky guy.
Old Sep 16, 2005 | 11:14 PM
CNSK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
I can't count the number of B-series clutches I've changed and I've never needed help from anyone doing it. Plus I'm a really lanky guy.</TD></TR></TABLE>
damn you must be good. Changing clutch is easy...its when you put back the tranny on...that sucker is heavey and you need to align it perfectly....I needed a extra hand.
Old Sep 17, 2005 | 12:18 AM
.water's Avatar
possible to show me a pic where to put screwdriver??
oh and do i need to drain coolent? and remove hose in TB area? thats what it says in helm, but i dont think my friend removed them
Old Sep 17, 2005 | 01:19 AM
TODA GS_R's Avatar
trust me... you dont need an extra person. those 10mm bolts, you just need to give it a good hit to impact them off...if you go slow and easy...itll spin...but one good smack would be koo
Old Sep 17, 2005 | 01:36 AM
dynamyks's Avatar
just changed mine a little while ago...you could do it yourself but better and faster if you do it with a friend...and i used a crowbar to keep the flywheel from spinning, it isnt very difficult
Old Sep 17, 2005 | 03:45 AM
happy_guy's Avatar
if its your first time.. definately have a friend help you. theres a whole bunch of bolts and ****. when my mechanic did it, he had 2 guys help him align the tranny back on
Old Sep 21, 2005 | 12:22 PM
.water's Avatar
wait when you unbolt clutch&flywheel it doesn move?? only moves when you tight them down??
Old Sep 22, 2005 | 03:25 AM
.water's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunkyDC2 &raquo;</TD></TR><TR><TD CLASS="quote">wait when you unbolt clutch&flywheel it doesn move?? only moves when you tight them down?? </TD></TR></TABLE>
anyone??
Old Sep 22, 2005 | 05:00 AM
IN VTEC's Avatar
It can break loose in any direction. It depends on how much constant force you put into tightening or loosening the bolts.
If you've got an impact wrench, use it to remove the bolts. That way you don't have to worry about the engine moving while loosening the bolts.
If you don't have an impact, take a 1/2" drive ratchet and 19mm deepwell socket. Set it to tighten (normal thread), and slap it on the crankshaft pulley bolt. Rotate the entire assembly until it hits the frame rail. When you go to loosen the flywheel bolts, it'll automatically brace the ratchet against the frame rail.
Do the opposite when you torque the bolts down. Check the crankshaft pulley bolt tightness when you're done.
Old Sep 22, 2005 | 05:44 AM
.water's Avatar
Default Re: People who changed their clutch. DIY (IN VTEC)
oh ok thanks for info
just one last question, is it bad when flywheel turning to clockwise?? cause when you do head work it has to be turn to counterclorkwise. thanks
Old Sep 22, 2005 | 08:10 AM
IN VTEC's Avatar
Clockwise rotation at the flywheel side is ok. Counter clockwise should be avoided on that side.
Old Sep 22, 2005 | 09:51 AM
gsrious's Avatar
why are you guys making it so hard... just put a screwdriver in between the teeths of the flywheel and the webing on the block. have someone hold it there and the other guy take out the bolts. simple as that. now go on and put knowledge to work. where you've failed, you know you're only closer to succeeding.
Old Sep 22, 2005 | 09:54 AM
Kendall's Avatar
Hmmm...
Based on the responses I'm reading I don't suppose anyone else has discovered what a transmission jack is. You don't need a friend to remove/install the tranny, you need a tranny jack.
Old Sep 22, 2005 | 09:57 AM
gsrious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm...
Based on the responses I'm reading I don't suppose anyone else has discovered what a transmission jack is. You don't need a friend to remove/install the tranny, you need a tranny jack.</TD></TR></TABLE>im pretty sure most of the people know what it is... or atleast i do. i just don't see the point of spending money on a product where you aren't even going to be using day after day, let alone years. just another handy person will do fine for me.
Old Sep 22, 2005 | 10:05 AM
Kendall's Avatar
Default Re: (gsrious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure most of the people know what it is... or atleast i do. i just don't see the point of spending money on a product where you aren't even going to be using day after day, let alone years. just another handy person will do fine for me.</TD></TR></TABLE>
Understood, but most places have some kind of a tool rental store that won't charge more than about about ten bucks a day for one. It's better to spend ten bucks and securely remove the transmission than it is to risk dropping it on someone.
Old Sep 22, 2005 | 10:27 AM
IN VTEC's Avatar
Who needs a tranny jack when you've got a 300lb friend.
Old Sep 22, 2005 | 03:37 PM
kuja's Avatar
Default Re: (IN VTEC)
yea if you have access to one by all means. I personally prolly wouldn't have been able to do it by myself, the trannys heavy and awkard. A friend of mine throws it on his chest, and lfts it up and on, but hes a small little bastard, i don't have any room to move around like that under my car.
