Head gasket or new engine
Old Sep 16, 2005 | 06:18 PM
Traymack1's Avatar
Default Head gasket or new engine
Hey I been a member 4 a while but i never post much. I have a '93 si and I'm pretty sure I have a blown head gasket (milky dots in oil). This is my secondary car and my project but i can't figure out what to do. I'm on a budjet so B series is out of the question. This is my second single cam stock d16z6 blown w/hydrolock over 2 years ago replaced with a JDM d15b, love the engine, so much fun on the highway. I just replaced the cam with a zex 59300 and now this(head Gasket). I could get another d15b for $375 and have it installed for $250 and the guy said that he would swap the cam out at no additional cost. Or, should i change the head gasket on the old engine. Also i have an overheating problem and i think it is because of the head gasket. Sorry for the long post but i just want to drive my hatch again, my G20 looks nice but it aint no Honda.
Old Sep 16, 2005 | 06:27 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: Head gasket or new engine (Traymack1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Traymack1 &raquo;</TD></TR><TR><TD CLASS="quote">Hey I been a member 4 a while but i never post much. I have a '93 si and I'm pretty sure I have a blown head gasket (milky dots in oil). This is my secondary car and my project but i can't figure out what to do. I'm on a budjet so B series is out of the question. This is my second single cam stock d16z6 blown w/hydrolock over 2 years ago replaced with a JDM d15b, love the engine, so much fun on the highway. I just replaced the cam with a zex 59300 and now this(head Gasket). I could get another d15b for $375 and have it installed for $250 and the guy said that he would swap the cam out at no additional cost. Or, should i change the head gasket on the old engine. Also i have an overheating problem and i think it is because of the head gasket. Sorry for the long post but i just want to drive my hatch again, my G20 looks nice but it aint no Honda.</TD></TR></TABLE>I would swap it because who knows how bad the hydrolocked engine is. Would most likely go well over $375 in parts and labor to rebuild it.
Old Sep 16, 2005 | 06:28 PM
graveltravel's Avatar
heck, do both!
do the head gasket for now, and by the engine for future reference!
Old Sep 16, 2005 | 07:00 PM
Traymack1's Avatar
Default Re: Head gasket or new engine (HondaFanatic708)
the first engine i had hydrolocked and i got rid of it for the current JDM d15b and this one has a blown head gasket.
Old Sep 16, 2005 | 07:11 PM
Oh I thought the D15B got hydrolocked. As long as there isn't any internal damage replacing the HG would be the cheaper alternative.
Old Sep 16, 2005 | 10:38 PM
Traymack1's Avatar
could the blown head gasket make the car overheat? what else could b wrong internally?
Old Sep 17, 2005 | 06:42 AM
Traymack1's Avatar
bump for a little more help on the head gasket
Old Sep 17, 2005 | 07:14 AM
dcp48's Avatar
yes blown headgaskets do over heat.. they also blow alot of condensation out of the muffler even at idle...
Old Sep 17, 2005 | 09:05 AM
cioli's Avatar
it is possible to be blown the headgasket and the car does not overheat ?
Old Sep 17, 2005 | 09:56 AM
Traymack1's Avatar
Default Re: (cioli)
yes i think that you can have a blown head gasket and not overheat, but it can get worse and then start causing overheating
Old Sep 17, 2005 | 10:19 AM
Default Re: (Traymack1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Traymack1 &raquo;</TD></TR><TR><TD CLASS="quote">yes i think that you can have a blown head gasket and not overheat, but it can get worse and then start causing overheating</TD></TR></TABLE> Yeah you could be losing compression through the head gasket and not overheat. Usually they do go hand in hand. As far as what else could be wrong to cause overheating, it could really be anything from a bad waterpump to something like a clog in the heater core or bad thermostat.
Old Sep 17, 2005 | 11:23 AM
Traymack1's Avatar
Default Re: (HondaFanatic708)
heat works when not overheating so eater core is fine, water pump replaced when i did the swap so i thik that it's ok and i took out the thermostat a while ago, i live in Florida so i'm pretty sure it's the head gasket. I just want o know that if i change the head gasket that will be all and my overheating problem is gone.
Old Sep 17, 2005 | 11:28 AM
e jay one's Avatar
well theres only one way to find out. i dont know what your future plans for the motor are but if you do do the head gasket put in arp head studs incase you wanna boost later. if it were me i would do the gasket.
Old Sep 17, 2005 | 01:28 PM
Default Re: (e jay one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one &raquo;</TD></TR><TR><TD CLASS="quote">well theres only one way to find out.</TD></TR></TABLE>
Zoe_civic
14
Dec 14, 2012 03:09 PM
d16y8EL
Mar 29, 2007 06:55 PM
bb4socal
Mar 9, 2006 03:30 PM
gsrious
Feb 5, 2006 09:22 AM
SFrogue85
Sep 5, 2004 04:07 PM
