DA GSR (rare??)
Old Sep 16, 2005 | 05:33 PM
TypeRobert's Avatar
Default DA GSR (rare??)
ok so y is it said that 92-93 GSRs are rare and does anyone have any info on their engine B17 i searched didnt find much anything special about this engine i just want to leran more about them also this would be an OBD0 car right? thanks any useful knowlege works like is the suspension different and the brakes engine obviously
Old Sep 16, 2005 | 05:39 PM
projectTeG's Avatar
sae brakes and suspension as the Da's the engine has 160hp and i think 117tq(basically a stroked b16)with one of the most agressive geared b-series trannies. its obd1 seeing obd1 is from 92-95. BTW the chassis code is Db2
Old Sep 16, 2005 | 06:24 PM
AllmansDB8*'s Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">sae brakes and suspension as the Da's the engine has 160hp and i think 117tq(basically a stroked b16)with one of the most agressive geared b-series trannies. its obd1 seeing obd1 is from 92-95. BTW the chassis code is Db2</TD></TR></TABLE>
Yeah, I was going to say there is no such thing as a "DA GS-R" - it's a DB2
& yes they are rare
Old Sep 16, 2005 | 06:47 PM
User 42624's Avatar
Default Re: (AllmansDB2)
cable tranny
Old Sep 16, 2005 | 07:00 PM
jdminspiredDB8's Avatar
Default Re: DA GSR (TypeRobert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRobert &raquo;</TD></TR><TR><TD CLASS="quote">about this engine i just want to leran more about them also this would be an OBD0 car right? </TD></TR></TABLE>
No, its OBD 1
Old Sep 16, 2005 | 11:03 PM
blk_db2's Avatar
Default Re: DA GSR (JDMG2INTEGRA)
considered a square motor... Bore 81mm x Stroke 81.4mm... 9.7:1 cr
the crank,rods and pistons are different than the B16, the rest is pretty much the same
Old Sep 17, 2005 | 04:35 AM
TypeRobert's Avatar
Default Re: DA GSR (blk_db2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Airific &raquo;</TD></TR><TR><TD CLASS="quote">cable tranny </TD></TR></TABLE>
It is? wow is that a bad thing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk_db2 &raquo;</TD></TR><TR><TD CLASS="quote">considered a square motor... Bore 81mm x Stroke 81.4mm... 9.7:1 cr
the crank,rods and pistons are different than the B16, the rest is pretty much the same</TD></TR></TABLE>
square?ok so this motor is more similar to a b16 than a b18c correct could i put a b18c crank and rods in there?
Old Sep 17, 2005 | 06:47 AM
projectTeG's Avatar
square?ok so this motor is more similar to a b16 than a b18c correct could i put a b18c crank and rods in there?</TD></TR></TABLE>
you could put i think youll need to get custom length rods or your pistons modified because the b16a ans b17a deck heights are shorter than the b18a/b,b16b,b20, and b18c/c5
Old Sep 17, 2005 | 05:13 PM
TypeRobert's Avatar
Default Re: DA GSR (projectTeG)
bump
what do you mean by most aggresive tranny? shorter longer? wuts it compare too?
Old Sep 17, 2005 | 06:18 PM
GrayT's Avatar
The short geared YS1 (The transmission code) is actually considered to be the shortest geared Honda transmission ever made. Given that the gears are so short you have the ability to accelerate faster, hence why so many people knab them up quick.
By the way, you don't want a DB2 (G2 GSR) they're pieces of ****. No one likes those things... I'd be ashamed.
Modified by GrayT at 8:30 PM 9/17/2005
Old Sep 17, 2005 | 06:56 PM
DAguyLS's Avatar
Default Re: DA GSR (GrayT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrayT &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by GrayT at 8:30 PM 9/17/2005</TD></TR></TABLE>
are you flippin serious?
Old Sep 17, 2005 | 07:08 PM
GrayT's Avatar
Default Re: DA GSR (DAguyLS)
Of course, why else would I own one?
Old Sep 17, 2005 | 07:30 PM
92integraVTECgsr's Avatar
I'd agree. in some ways its ****(NO LOW END POWER) but i do LOVE my 92 DB2.
Also, there were only 4000 made from 92-93.. so very hard to find these days if you take accidents and scrapped into considerations.
the 1.7L VTEC motor.. its nice.. and from reading some information in honda-tuning, there is very little stress on the piston rings and walls on these motors.
I wish they were 800-1000 pounds lighter.. that would change the whole feel of the car.
tranny = shortest geared tranny Honda every brought to the street.
and a 8000 Redline.. the cars sounds and feels great about 4000 RPM.
Old Sep 17, 2005 | 08:11 PM
UNKNOWN_MEMBER's Avatar
Default Re: DA GSR (92integraVTECgsr)
tranny feels good. has armrest. um....no 3rd brake light on rear windsheld, it's on the spoiler. doesn't have middle x-member bracing. that's all i can think of right now. they're pretty quick also.
Old Sep 18, 2005 | 01:47 AM
standinghollow's Avatar
Default Re: DA GSR (UNKNOWN_MEMBER)
Btw i just spotted one im looking at tom for 2900 with 106k 1 owner for my brother Think its worth it?
Old Sep 18, 2005 | 04:59 AM
TypeRobert's Avatar
Default Re: DA GSR (standinghollow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrayT &raquo;</TD></TR><TR><TD CLASS="quote">The short geared YS1 (The transmission code) is actually considered to be the shortest geared Honda transmission ever made. Given that the gears are so short you have the ability to accelerate faster, hence why so many people knab them up quick.
By the way, you don't want a DB2 (G2 GSR) they're pieces of ****. No one likes those things ... I'd be ashamed.
hmm im sure you can find alot of people here that will disagree with u
so basically the transmission helps alot in acceleration but like a B16 theres not much torque are b18 part interchangable? like header valve trains and such?
Old Sep 18, 2005 | 07:22 AM
I think GrayT was just making a joke... I think
Old Sep 18, 2005 | 08:25 AM
2900, 1 ownew 106,xxx miles.. hmm.. will be a good deal if everything is ok with it.
Old Sep 19, 2005 | 09:29 PM
omg looked at it today.Im so kicking myself right now.It was in the paper for one day and like 7 people showed up almost the same time.There was an older lady that pulled in the same second I did just in front of me.It was owned by an older high class couple that kept this thing new.It was soooooo clean and garaged the whole time they owned it.
It was the cleanest 2nd gen iver ever seen.She decided to buy it for her son that just blew up two toyotas.Too bad its going to some ricer,damn sad.If only i was 10 seconds earlier.It would be in my damn yard right now.My brother even tried offering 3500 instead of 2900 but the seller wanted to be fair so we are looking around again.So if anyone knows of one for sale in the albany ny area selling a 3rd gen gsr.We would be interested.Damn spoiled ricers.
Old Sep 19, 2005 | 11:32 PM
Teglessb18's Avatar
I got one and I got it for pretty cheap (I think) 2300 w/140k and not to mention its black and its CDM YO!!!!!!!!!!!! haha no auto seatbelts for me and it came with that center armrest console. (but the plastic piece on the cupholders is broken) . Get one if you get the chance you wont regret it.
Old Sep 19, 2005 | 11:39 PM
happy_guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standinghollow &raquo;</TD></TR><TR><TD CLASS="quote">omg looked at it today.Im so kicking myself right now.It was in the paper for one day and like 7 people showed up almost the same time.There was an older lady that pulled in the same second I did just in front of me.It was owned by an older high class couple that kept this thing new.It was soooooo clean and garaged the whole time they owned it.
It was the cleanest 2nd gen iver ever seen.She decided to buy it for her son that just blew up two toyotas.Too bad its going to some ricer,damn sad.If only i was 10 seconds earlier.It would be in my damn yard right now.My brother even tried offering 3500 instead of 2900 but the seller wanted to be fair so we are looking around again.So if anyone knows of one for sale in the albany ny area selling a 3rd gen gsr.We would be interested.Damn spoiled ricers.</TD></TR></TABLE>
you shoulda known man.. with those kinda cars you must INSIST that they let you down there ASAP! thats how I got my 95 GSR, there was 30 people that wanted it, and I hella insisted that the guy let me come down that same day instead of the following day like everyone else. I kept insisiting so he said ok come to my work. and thats how I got my car
i cant believe she wouldnt sell it for 3500, thats ******* dumass rich people, 600 dont mean nothing to them cuz they wanna be "fair" if it was me I'd be like **** that you two gotta start bidding on it! hahaha
2900 for a 92 gsr 106k one owner thats one hell of a deal i would pick it up even though i dont like DA you know how good a deal that is
Old Sep 19, 2005 | 11:53 PM
Mr. Potato Head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by happy_guy &raquo;</TD></TR><TR><TD CLASS="quote">you shoulda known man.. with those kinda cars you must INSIST that they let you down there ASAP! thats how I got my 95 GSR, there was 30 people that wanted it, and I hella insisted that the guy let me come down that same day instead of the following day like everyone else. I kept insisiting so he said ok come to my work. and thats how I got my car
2900 for a 92 gsr 106k one owner thats one hell of a deal i would pick it up even though i dont like DA you know how good a deal that is</TD></TR></TABLE>
^ good tip
i'll remember that next time
Old Sep 20, 2005 | 05:02 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
rare...well...yeah
they were only made 92-93...rare by default
the trans is JUST SHORT of an ITR trans...a seriously nice upgrade...
Old Sep 20, 2005 | 05:19 AM
Rajin's Avatar
Default Re: DA GSR (DAantagonist)
I have one of the short gear YS1s on my LS engine, too bad when I go boost its gonna be a pain to drive.
Old Sep 20, 2005 | 07:25 AM
Default Re: DA GSR (Rajin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rajin &raquo;</TD></TR><TR><TD CLASS="quote">I have one of the short gear YS1s on my LS engine, too bad when I go boost its gonna be a pain to drive.</TD></TR></TABLE>
try and get a LS 5th....it's worth it lol...andI don't think it would be a pain to drive, it would be a nice thing really...
