Proper way to shave side mouldings?
Old Sep 16, 2005 | 04:08 PM
nuckingfuts's Avatar
Default Proper way to shave side mouldings?
i would assume welding in some kind of patch but the holes are so small? i saw someone on here fill in the hole all with wire but that would make the door so hot and most likely warp??
Old Sep 16, 2005 | 08:52 PM
EKFerioHawaii's Avatar
Default Re: Proper way to shave side mouldings? (nuckingfuts)
just use duramix 4179 or the proper setting formula.
patch with sheetmetal and bond. simple.
no welding. bonds and seals really good.
ps. make sure you get the right application gun and alot of tips.
Old Sep 17, 2005 | 08:42 AM
Default Re: Proper way to shave side mouldings? (EKFerioHawaii)
i am searcing on google for duramix, with the moisture and temperature changes does this stuff swell up or pop out at all? i try to use a small amount of filler as i'm sure you do too, just wondering if you know this stuff works good from first hand experience?
a267mm
Welding / Fabrication
14
Nov 21, 2013 04:19 AM
93FastLs
Apr 29, 2004 10:26 PM
DC2 to AP2
Mar 10, 2004 07:00 AM
Audio28
Jan 8, 2003 07:41 PM
964drVic
Oct 26, 2002 06:09 PM
