rotor no come off
Old Sep 16, 2005 | 03:08 PM
redryder's Avatar
Default rotor no come off
I've done everything needed to get to point of just sliding rotor off. Used impact wrench. The rotor is stuck on there. Is it safe to wack that fckr from behind. Could the lug nut bolts be so rusted that its preventing the rotor to come off. Any advice please would be much abliged
Old Sep 16, 2005 | 03:20 PM
drdisco69's Avatar
Default Re: rotor no come off (redryder)
...did you take off the screws holding the rotor to the hub?
Old Sep 16, 2005 | 03:23 PM
redryder's Avatar
yes, i only had two screws hold the rotor on the hub. used impact wrench for that. the damn rotor just wont budge
Old Sep 16, 2005 | 03:27 PM
shawn_crx's Avatar
It should come off
hit it front behind with you plam.
just double check did you take the caliper off
Old Sep 16, 2005 | 03:33 PM
redryder's Avatar
got it guys. Thanks for the reply's, time for the other side
Old Sep 16, 2005 | 03:39 PM
.Ry's Avatar
.Ry
Posting this is a reference. If you look closely there are 2 small holes on your rotor that are not used. Take two 8mm threaded bolt and screw them in. Once you get them in the rotor will pop loose. Works everytime.
thaseint
Suspension & Brakes
Feb 6, 2007 06:38 PM
sickofitall1113
Jun 2, 2005 12:01 PM
turbo01LS
Feb 19, 2005 08:41 PM
Draggin99Si
Sep 5, 2003 06:43 PM
totaled
Mar 15, 2003 06:56 PM
