CRX DX engine problems...
Old Sep 16, 2005 | 01:39 PM
super_mike's Avatar
Default CRX DX engine problems...
Basicly the problem is it won't crank, it turns over but I just can't get it to crank, I replaced the ECU not too long ago because it had water leaking on to it so we thought that might be the problem but no such luck... we also changes the distributor, spark plugs, spark plug wires and timing belt (old one was broken). the only thing me and we can think of is either there is a problum with the injectors or the timing belt is off.
Does any body know te best ways to test those two thing or have any other ideas about what the problum could be?
Drew
Old Sep 16, 2005 | 02:35 PM
drussell4801's Avatar
Default Re: CRX DX engine problems... (super_mike)
the basics needed for a motor to run are spark, fuel, and compression. Check those three things.
pink_nightmare
Jun 28, 2010 07:29 PM
91rexhf
40
Jan 27, 2009 09:45 PM
igotthatjdmshit
12
May 6, 2008 05:29 AM
DetroitPOScivic
37
Jun 10, 2004 08:07 AM
TheIntegraGuy
Aug 16, 2003 02:45 PM
