Getting the Spoon ABS lip but doesn't come with mounting hardware
Old Sep 16, 2005 | 01:30 PM
unknown0001's Avatar
Default Getting the Spoon ABS lip but doesn't come with mounting hardware
Hey guys I've scored a deal with either a ABS or Urethane Spoon Sports style lip (NOT MUGEN V2/Spoon V2) but it doesn't come with any mounting hardware.
Any ideas on how I would go about mounting the lip? does the CF spoon lip come with an L-bracket to install it?
any ideas would be appreciated
Old Sep 16, 2005 | 01:35 PM
$amGD3's Avatar
Swaggylicious
If it's abs,screws should be the only thing you need to put them on
Old Sep 16, 2005 | 01:50 PM
ludaboy93's Avatar
Default Re: (sam21)
wheres are u getting the lip? i live in ontario also and am trying to find one for my 4thgen lude.
Old Sep 16, 2005 | 02:14 PM
1bar_ek's Avatar
Default Re: (1bar_ek)
Got my spoon sports style lip from ABS with hardware kit!
Old Sep 16, 2005 | 02:21 PM
5STAR3's Avatar
Default Re: (1bar_ek) (1bar_ek)
self tapping screws.
Old Sep 16, 2005 | 02:31 PM
Default Re: (1bar_ek) (5STAR3)
thanks guys, talked to the owner about it and another friend on installing it.
I thought I'd have to make L-brackets but that doesn't seem to be the case
Old Sep 24, 2005 | 06:49 AM
Default Re: (1bar_ek) (Mr.RHTuner)
hey guys, what if the lip is fiberglass??? would I still go about using self tapping screws? or just use standard 10mm bolts, washers and nuts?
Modified by Mr.RHTuner at 12:53 PM 9/24/2005
Old Sep 24, 2005 | 09:09 AM
Canttx's Avatar
i had a spoon copy lip in fiberglass, i used self tapping screws and it held up fine...would have preffered to used bolts but never got around to it.
Old Sep 24, 2005 | 09:30 AM
Default Re: (1bar_ek) (Canttx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Canttx &raquo;</TD></TR><TR><TD CLASS="quote">i had a spoon copy lip in fiberglass, i used self tapping screws and it held up fine...would have preffered to used bolts but never got around to it.</TD></TR></TABLE>
hey were are you from??? if it's the fiberglass copy I'm pretty sure I have the same on you got.
There wasn't many produced and mine is stamped with 199 on the side.
how did it hold up?(lip itself)
Old Sep 24, 2005 | 09:45 AM
Canttx's Avatar
in ontario aswell,
got mine from a friend almost 2 years ago, i dont recall mine being stamped but i could be wrong.
my lip held up pretty good actually, took alot of scrapes, sometimes even smacked it on the highway cause my car was alittle low, but it stayed on there. the screws on the side of the bumper actually ripped out one time, but the lip was still there.
its pretty beat up now, but it lasted alot longer than i thought it would.
back in 2003
Old Sep 24, 2005 | 09:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Canttx &raquo;</TD></TR><TR><TD CLASS="quote">in ontario aswell,
back in 2003
sick car man...
you heard about the h-t meet in Kitchener for tomorrow?
Old Sep 24, 2005 | 09:51 AM
Canttx's Avatar
yeah, im hoping to be there,
most likely in an integra.
Old Sep 24, 2005 | 09:58 AM
buyer's Avatar
super glue that bia bia
Old Sep 24, 2005 | 10:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Canttx &raquo;</TD></TR><TR><TD CLASS="quote">yeah, im hoping to be there,
most likely in an integra.</TD></TR></TABLE>
awesome...what does your integra look like? I'll look for your car there
Old Sep 24, 2005 | 10:09 AM
Canttx's Avatar
red integra with a mugen wing.
Old Sep 24, 2005 | 10:29 AM
rocaveli's Avatar
Default Re: Getting the Spoon ABS lip but doesn't come with mounting hardware (Mr.RHTuner)
where did u order the lip?
Old Sep 24, 2005 | 10:31 AM
Default Re: Getting the Spoon ABS lip but doesn't come with mounting hardware (rocaveli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocaveli &raquo;</TD></TR><TR><TD CLASS="quote">where did u order the lip?</TD></TR></TABLE>
found it locally...buried under other treasure
Old Sep 24, 2005 | 10:34 AM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">hey guys, what if the lip is fiberglass??? would I still go about using self tapping screws? or just use standard 10mm bolts, washers and nuts?
Modified by Mr.RHTuner at 12:53 PM 9/24/2005</TD></TR></TABLE>
You can, but years ago, when I had a fiberglass Spoon style lip, I used nut/bolt/washer combos to hold it more secure and to help avoid theft. I installed the bolts in an order, one facing up, and one facing down all the way across so it would be a bitch for a theif to take off, unless they took off the whole bumper
Old Sep 24, 2005 | 10:56 AM
kingSfit's Avatar
zip tie
Old Sep 24, 2005 | 11:32 AM
snowman0520's Avatar
i want one. any word when jdmshit is coming out with theirs
Old Sep 24, 2005 | 02:33 PM
Default Re: (1bar_ek) (rodrez.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez. &raquo;</TD></TR><TR><TD CLASS="quote">You can, but years ago, when I had a fiberglass Spoon style lip, I used nut/bolt/washer combos to hold it more secure and to help avoid theft. I installed the bolts in an order, one facing up, and one facing down all the way across so it would be a bitch for a theif to take off, unless they took off the whole bumper </TD></TR></TABLE>
Thanks for the info rodrez...I did the same technique so dosen't seem the lip will be comming off.
thanks to all...the lip is mounted and pics will come soon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowman0520 &raquo;</TD></TR><TR><TD CLASS="quote">i want one. any word when jdmshit is coming out with theirs</TD></TR></TABLE>
sorry not sure man...PM newman but I've heard about that lip since a bazillion years ago
Old Sep 24, 2005 | 08:31 PM
jay.dee.em1's Avatar
you should try riveting it on the sides to avoid theft and also drill a few small holes on the bottom of the lip to where it corresponds on the bumper and use nuts and bolts to secure it .. just take a trip to your local home depot or loews or even a hardware store
Old Sep 24, 2005 | 09:51 PM
here are some new pics with the lip
Old Sep 24, 2005 | 10:39 PM
h22a_ej's Avatar
love that lip
Old Sep 24, 2005 | 10:42 PM
Doeboy's Avatar
damn! i want one too.
