Oil feed line....
Old Sep 16, 2005 | 12:43 PM
92 4doorsleeper's Avatar
Default Oil feed line....
Is where I have my oil feed for turbo an ok place?
Old Sep 16, 2005 | 01:21 PM
Default Re: Oil feed line.... (92 4doorsleeper)
I know somebody can answer my question
Old Sep 16, 2005 | 02:59 PM
This is honda tech right??? so where the hell are all the honda techs?
Old Sep 16, 2005 | 03:05 PM
EJ1 wilcox's Avatar
I have seen a few people run their oil feed from there... and I can't remember why, but I read that it isn't a good idea.
Most people just run them off the back of the block from the stock oil pressure sensor location. That's where I'm running mine from.
You would get more help from the forced induction section. Maybe try reposting this thread in there. Or get a mod to move it for you.
Old Sep 16, 2005 | 03:12 PM
Default Re: Oil feed line.... (EJ1 wilcox)
thank you very much... anyones got anything about it being there?
Old Sep 16, 2005 | 04:07 PM
IMALLSLO's Avatar
No!!!!! Change it imediatelly. It only has sufficient oil pressure under Vtec. At idle pressure is around 3 PSI. If you dont chnage it you will kill the bushing/bearing. Ask how I know?..........ive seen a 2500 turbo die as a result of this exact set-up. This port is for testing Vtec pressure only!
Old Sep 16, 2005 | 05:17 PM
EJ1 wilcox's Avatar
Default Re: Oil feed line.... (IMALLSLO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMALLSLO &raquo;</TD></TR><TR><TD CLASS="quote">No!!!!! Change it imediatelly. It only has sufficient oil pressure under Vtec. At idle pressure is around 3 PSI. If you dont chnage it you will kill the bushing/bearing. Ask how I know?..........ive seen a 2500 turbo die as a result of this exact set-up. This port is for testing Vtec pressure only!</TD></TR></TABLE>
Ahhh... that's the reason I couldn't remember... I remember now.
dfoxengr's Avatar
there is no pressure coming from there.
you need it directly off of an oil passage, from the pump
Old Sep 16, 2005 | 05:27 PM
slomofo's Avatar
GDD Member
Take it from a T in the sending unit or else take it from one of the two spots in behind the distributor.
Old Sep 16, 2005 | 05:28 PM
mmuller's Avatar
Mad Scientist
damn that was close to disaster...
Old Sep 16, 2005 | 05:35 PM
dfoxengr's Avatar
Default Re: Oil feed line.... (mmuller)
pm me if you need a real oil line.
Old Sep 16, 2005 | 05:47 PM
IMALLSLO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">damn that was close to disaster...</TD></TR></TABLE>
Possibly not. The original poster is offline and hasnt seen this post yet. Hes probally on the freeway right now giving all his buddies test drives and has no clue on whats gonna happen.
Old Sep 17, 2005 | 07:06 AM
Default Re: (slomofo)
So the plug on the back of the headby the dizzy is a good place? like where everyone hooks ls,b20/vtec lines at?
oh yeah Ive yet to even start the car btw
Old Sep 17, 2005 | 07:50 AM
zccr-xsi's Avatar
tap it off your oil filter.if u tap the pan wont be enough pressure cause the pump will pick it up before it reasches the line.or u could TAP IT OFF A oil relocator that be good place too.
Old Sep 17, 2005 | 09:04 AM
dfoxengr's Avatar
Default Re: (92 4doorsleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 4doorsleeper &raquo;</TD></TR><TR><TD CLASS="quote">So the plug on the back of the headby the dizzy is a good place? like where everyone hooks ls,b20/vtec lines at?
oh yeah Ive yet to even start the car btw</TD></TR></TABLE>
no dude, that is a no pressure INPUT. pm me to buy what you need for 45$. a complete oil line kit for your turbo, that tee's off of the oil pressure sender at the back of the block.(to the left of the oil filter)
Old Sep 17, 2005 | 09:16 AM
IMALLSLO's Avatar
Default Re: (dfoxengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">
no dude, that is a no pressure INPUT. pm me to buy what you need for 45$. a complete oil line kit for your turbo, that tee's off of the oil pressure sender at the back of the block.(to the left of the oil filter)</TD></TR></TABLE>
Thats the only place I recommend!
B18EG6
Mar 25, 2012 06:20 AM
screen_name
Apr 23, 2005 07:22 AM
wade
Oct 10, 2004 07:38 PM
cdog19
Feb 9, 2004 01:15 PM
Acura_I-RS
Mar 16, 2003 04:45 PM
