Another Main Relay Problem
Old Sep 16, 2005 | 10:14 AM
91hatch757's Avatar
Default Another Main Relay Problem
Okay I have searched all the posts on this but I think everyone is different so heres my story! I was replacing the valve cover and oil pan gasket and after finishing that up went to start the car and my main relay is buzzing and nothing happens when you try to crank. Check the grounds for the thermostat and the valve cover and even used another car trying to jump start just in case of a dead battery and still nothing. The weird thing is even when connecting the battery directly to the positive side of the starter all it does is click. Without the battery nothing happens. Bought a new main relay and no change. All the lights on the dash come on except the three to the left where the CEL light is dimer than the rest and goes off while cranking. Any suggestions?
Old Sep 16, 2005 | 12:35 PM
91hatch757's Avatar
Default Re: Another Main Relay Problem (91hatch757)
Please anyone? I am here to try and answer questions all night!
Old Sep 16, 2005 | 12:40 PM
CBURKE's Avatar
check you fuses? you also need to turn the key to the on poss, and look at you ecu. count the number of flashing lights and then get back to me. If nothing comes on the you are not getting power to the ecu and that means it's the relay. Did you buy it new?
Old Sep 16, 2005 | 12:42 PM
Zeppelin's Avatar
Sounds like your battery is dead. Just because you jump it from another car does not prove it is not the battery. Check your battery voltage, then turn the key and try to start it. What is the voltage when trying to start it?
Old Sep 16, 2005 | 01:02 PM
91hatch757's Avatar
Default Re: (CBURKE)
When you turn it to on the ECU light never goes away! Checked with different ECU's and get the same problem! Relay was bought brand new!
Old Sep 16, 2005 | 04:03 PM
slow hatch's Avatar
Default Re: (91hatch757)
i hate honda main relays, grrrrrr............. sorry had to vent
Old Sep 16, 2005 | 05:09 PM
turbo_ef9's Avatar
Default Re: (slow hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow hatch &raquo;</TD></TR><TR><TD CLASS="quote">i hate honda main relays, grrrrrr............. sorry had to vent</TD></TR></TABLE>
yea tell me about it.. the soldered areas on my old relay all cracked so my car wasnt starting.. got a new one off an 88 ledgend and it works fine now.. i went a resoldered all my connections on the old one and now that one works as well.. stupid main relays.. suck ***.. hope you find your problem.. i would check with fuses and another battery..
Old Sep 17, 2005 | 04:34 AM
CBURKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91hatch757 &raquo;</TD></TR><TR><TD CLASS="quote">When you turn it to on the ECU light never goes away! Checked with different ECU's and get the same problem! Relay was bought brand new!</TD></TR></TABLE>
ok, well it's not the relay then because you would get no power to the ECU if it was bad too. Now, did you check the fusees? If that is not it check your distributor. It's just one more thing on these cars that go out all the time. See if you have any spark. You can do this by putting a screw driver in one of the plug wires and setting it on some metal like your valve cover. If you don't see any spark then you may have found your prob. Good luck and let me know.
ek coupe
10
Mar 5, 2010 05:02 PM
bdubnyc
Sep 4, 2008 07:07 PM
reno96teg
Apr 23, 2008 01:52 PM
rass1313
Apr 14, 2006 02:41 PM
messeduprex
Feb 8, 2006 10:17 PM
