Quick question....about o2 sensor replacement.
Old Sep 16, 2005 | 09:43 AM
red_EF9Si's Avatar
Default Quick question....about o2 sensor replacement.
My ecu is throwing a bad o2 sensor code but I not sure which of my 2 sensors is the one thats bad. So my question is: Is there a simple way to check the o2 sensors to see if they're ok or not? voltmeter? Thanks in advance.
Old Sep 16, 2005 | 02:33 PM
red_EF9Si's Avatar
bump sukahs!
Old Sep 16, 2005 | 02:44 PM
drussell4801's Avatar
Default Re: (red_EF9Si)
the one wire o2 sensors are dirt cheap.
what kind of car do you have?
Old Sep 16, 2005 | 02:55 PM
red_EF9Si's Avatar
Default Re: (drussell4801)
it's a 90 hatch with a b16 swap. i ordered the sensor from ebay for like 30 bux and it took them almost 3 1/2 weeks for them to ship it to me. I just want to make sure i replace the right sensor the first time.
Old Sep 16, 2005 | 03:23 PM
the b16 uses the same sensor as your car does in stock form.
you can get one for your car from advance auto. $40 for the direct plug in, $17 for the cut and splice universal ones.
edit: btw, that's if you're still obd0
4tika4
Jul 25, 2009 05:23 AM
94_CRVtec
Aug 29, 2005 10:31 AM
cu3tip
Oct 18, 2004 09:45 PM
cu3tip
Oct 18, 2004 08:26 PM
