b18 maximum bore size
Old Sep 16, 2005 | 07:54 AM
jmcmil6's Avatar
Default b18 maximum bore size
can somebody tell me what the maximum bore size you can use for an all motor application on a b series motor if its sleeved...?????????
i know golden eagle will do a special sleeve for all motor only up to 91mm, but i dont kno if they were only speaking specifically for a prelude motor...
Old Sep 16, 2005 | 08:59 AM
Luserkid's Avatar
Default Re: b18 maximum bore size (jmcmil6)
I read somewhere about 94mm. But dont quote me on it, it could have just been 91mm.
Old Sep 16, 2005 | 09:28 AM
jmcmil6's Avatar
Default Re: b18 maximum bore size (Luserkid)
wow 94mm?
thanks for the input.. anyone else?
Old Sep 16, 2005 | 09:45 AM
Kendall's Avatar
87mm on most aftermarket sleeves. 84.5mm with a Dart block, and about 81.5mm on stock sleeves. Most of the time 85mm is as big as you really want to go with a street motor, certain companies have had good amounts of success with 86mm motors. Most of the time anything larger than 85 is reserved specifically for race motors that won't see a lot of use before being torn down and rebuilt.
Old Sep 16, 2005 | 09:54 AM
jmcmil6's Avatar
Default Re: (Kendall)
thanks.. that sounds more like it.. i didnt think 91mm in a b series block would really be a possibility.. a h-series. yeah since its 87mm stock... so an extra 4mm isnt that bad.. but 10mm...wow...
Old Sep 16, 2005 | 09:56 AM
greenblurr93's Avatar
Default Re: (jmcmil6)
ya i heard Max bore for all motor is 85mm... but personally i would go 84mm, that way you have room to bore it again if something goes wrong.
f20b jones
80
Jun 11, 2011 12:10 AM
99hondacura
Jan 30, 2007 12:44 PM
hOndafienD 04
Oct 27, 2004 02:10 PM
mugen99
Jun 19, 2004 10:08 PM
calib17a
Mar 18, 2004 01:17 AM
