90 ef b16a to b18c
ok the motor is in but i need to know what these wires are im still using obd0 harness 2 white wires with yellow stripe, bright yellow wire (vtec?)and
red these are all running from ecu throu fire wall were do thay go
all so there was a plug on the old b16 it went to the back of the block there is no sensor like this on the gsr it has 2 small conectors on it i was told that was for the fans and to just connect the 2 wires and my fan will always be ON tru or false
I am not sure about your first ? but the second question I can answer.
The sensor you are talking about is the fan switch. On newer motors this sensor was moved from the back of the block to the thermostat housing.
b16acrxer
Dec 8, 2003 04:38 PM
paybac4223
Mar 19, 2003 02:29 PM
