wierd clicking noise, not axles
Old Sep 16, 2005 | 12:19 AM
HECTIC's Avatar
Default wierd clicking noise, not axles
i have a 98 civic with a 96 b18b1 swap, when i first drive the car like right after it has warmd up a little. i hear this very wierd clicking noise coming from what seems either the tranny or axles. so i had the axles replaced with new ones. but the noise continued. it only does it while traveling at very low speeds and while pressing on the gas but as soon as i let go of the gas it stops. and usually it wont do it at higher speeds like anything past 20 mph i changed out my tranny fluid with oem honda fluid. and nothing the noise continues. what can it be. please help. and sorry for the long post.
THANX
Old Sep 16, 2005 | 02:22 PM
SockEG's Avatar
Default Re: wierd clicking noise, not axles (civiteg98)
could be the backing plates hitting the rotors.
Old Sep 16, 2005 | 10:01 PM
Riced out's Avatar
It could be your U-Joints or your Trany mounts.
Old Sep 17, 2005 | 08:22 PM
Hecdosage's Avatar
could be your starter going hope you still kept your old axles.
Old Sep 17, 2005 | 09:09 PM
RudeBwaiSi's Avatar
I had a similar problem just few weeks ago, only difference is, I would still hear the sound even when my foot is off the throttle. Turned out to be tranny mount bolt, the threading in the tranny got chewed and the bolt was loose. I took it out and the noise went.
Old Sep 18, 2005 | 10:42 AM
fishhead's Avatar
that kind of sounds like when you put zip-ties around someones axels. He He .....
Old Sep 20, 2005 | 06:42 PM
HECTIC's Avatar
thanx alot for all the advice guys hopefully this will help ill update if it works .thanx again
Old Sep 23, 2005 | 08:53 AM
pny1981's Avatar
Default Re: (civiteg98)
What about wheel bearings. I am having the same problem.
batto24GSR
Sep 7, 2012 09:42 AM
mrbutters
Feb 2, 2009 12:38 PM
4everVtec
11
Nov 14, 2006 04:44 PM
GX8PRO
Jun 23, 2004 04:56 AM
Sketch_hs
25
Jul 27, 2003 02:06 PM
