Fields Vtec Controller ?
Old Sep 15, 2005 | 10:13 PM
Jdmglenn's Avatar
Default Fields Vtec Controller ?
ok i got a 96 hb with a GSR motor. Just recently installed the vtec controller only for using the vtec adjustments. I didnt hook up the map sensor wire to the map.. Qustion is why are the Rpms and the Speed on the Controller so far off from the ones on the cluster??
thanks
Old Sep 15, 2005 | 10:30 PM
komat's Avatar
Default Re: Fields Vtec Controller ? (JdmGlenn)
what is so off
by 100rpm or 1000rpm or 2000rpm or whatever it is
Old Sep 15, 2005 | 10:38 PM
Jdmglenn's Avatar
like i rev the engine to 2000rpm on the dash tach, the Fields says its at 2400rpm
Old Sep 15, 2005 | 10:51 PM
sicky's Avatar
grammer nawzi
Default Re: (JdmGlenn)
Are you planning on tuning with the fields or just changing vtec engagement?
Old Sep 15, 2005 | 11:15 PM
Jdmglenn's Avatar
just changing vtec engagement. It seems like EVERYTHING on the Fields is off
Old Sep 15, 2005 | 11:17 PM
B_CRUZ!'s Avatar
did you solder the wires? or just crimp?
Old Sep 15, 2005 | 11:22 PM
sicky's Avatar
grammer nawzi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmGlenn &raquo;</TD></TR><TR><TD CLASS="quote">just changing vtec engagement. It seems like EVERYTHING on the Fields is off </TD></TR></TABLE>
Let me post this one more time:
VAFCs or any other type of VTEC controller. They simply provide +12v to the VTEC solenoid at whatever RPM is specified. Some of you may think this is great. BUT (There's always a but isn't there) the VTEC controller does not communicate with the ECU in any way, shape, or form. The ECU has two separate sets of maps that it uses for VTEC applications. A low cam set when VTEC is not active and a high cam set when VTEC is activated. When ECU engages, the ECU switches maps to provide the engine with the correct ignition curves and fuelin for the higher cam lobes. Even though you can specify when the VTEC engages with a VTEC controller the ECU still switches maps at it's stock programmed point. If you set VTEC lower than stock you are in high cam while still running on the low cam maps until the ECU's programmed point. If you set VTEC higher than stock you're in high cam maps while you're still in low cam from the ECU's stock point until the VTEC controller's set point. Adjusting the VTEC point with a VAFC can cause a lean or rich condition and force you to use the VAFC to adjust fuel during the tuning process, which would adjust your ignition timing (as mentioned above) even more. Now, not only are you not in the correct maps, but the VAFC is changing the MAP sensor voltage and your ignition curve is going all over the place.
Old Sep 16, 2005 | 12:37 PM
Jdmglenn's Avatar
This still applies even though i didnt hooked up the map sensor to the Vtec controller?
Old Sep 16, 2005 | 05:05 PM
unclepowers's Avatar
thats the weirdest sh*t i ever heard..the fields is usually right on the money..did u put in indiglo gauges or change/alter the gauges in any way..??
Old Sep 16, 2005 | 10:01 PM
Jdmglenn's Avatar
nope. i just plugged in the 00 si cluster.
Old Sep 16, 2005 | 10:06 PM
EK k kay's Avatar
Stock clusters are known to be off by 3-400rpms.
Old Sep 18, 2005 | 10:13 PM
Jdmglenn's Avatar
Fields is gay, rippin it out
baseball_aj
Honda Civic (2001 - 2005)
11
Jul 26, 2007 07:09 AM
Wazup
Aug 13, 2003 08:24 PM
k193sup
Jul 23, 2002 10:47 AM
