Quick ?. CTR pistons in b16a2 ? Clearance?
Hey guys Im not a nOOb just a dseries guy..But I have a b16a2 I got for cheap from friend and was just wondering if there is any issues w/ fitment or clearance problems w/ valvetrain in there?? Thanks Guys, Kyle
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaperformance »</TD></TR><TR><TD CLASS="quote">They were designed to be used with the b16 platform.</TD></TR></TABLE>
They were designed to work with a 7mm taller deck and longer rods...
B16b(ctr) and b16a are two different blocks. The b16b is essentially the same block as a B18c(gsr). Even though its a 1.6, it has the same deck height as a b18c. Ctr's in a b16 will raise the compression of your b16 to over 11:1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by berettagtz117 »</TD></TR><TR><TD CLASS="quote">Ok so mixed opinions.. WIll they work fine ??</TD></TR></TABLE>
Yes, they will work fine, in currently running a b16a with ctr pistons, stock headgasket and skunk pro1's with no problems.
