misfortune with my 00 si
So to start... my si started burning oil like 20k ago... im a full time student and work full time aswell so i havent really had a chance to take her apart to find out whats going on. 3 weeks ago im driving down the 10 freeway and i just feel a massive power loss and started decellerating my check engine light started flashing and i knew i was fucked . i got home and did a compression check on her.. and had no compression on the # 2 cylinder
i decided to take her apart 2 days ago cuz i finally got a chance too... and my end results were a broken valve and a bunch of other burnt valves
in addition i had some pretty bad carbon build up considering that i did a decarb service only 7k ago.. im guessing what happen was since i had so much carbon on my pistons it just made my cumbustion chamber temp really high and burnt the **** out of my valves.. and my oil consumption... since it was like...a quart every 3 days for like 150 miles im guessing my oil rings were bad.. i still need to take the bottom block apart...
Modified by code415 at 2:21 PM 9/16/2005
Modified by code415 at 2:22 PM 9/16/2005
Modified by code415 at 2:23 PM 9/16/2005
Modified by code415 at 4:37 PM 9/16/2005
in addition i had some pretty bad carbon build up considering that i did a decarb service only 7k ago.. im guessing what happen was since i had so much carbon on my pistons it just made my cumbustion chamber temp really high and burnt the **** out of my valves.. and my oil consumption... since it was like...a quart every 3 days for like 150 miles im guessing my oil rings were bad.. i still need to take the bottom block apart... Modified by code415 at 2:21 PM 9/16/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2nR22 »</TD></TR><TR><TD CLASS="quote">damn thats sucks bro. hey out of curiosity how do you know or how can you tell if your engine is burning oil?</TD></TR></TABLE>
Check the dipstick, dipstick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR »</TD></TR><TR><TD CLASS="quote">
...uhh DUH! but what do you look for?
</TD></TR></TABLE>...uhh DUH! but what do you look for?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2nR22 »</TD></TR><TR><TD CLASS="quote">...uhh DUH! but what do you look for?</TD></TR></TABLE>
Was that serious?
Was that serious?
you cant be serious you look for a loss of oil on the dipstick. if you are losing oil and you dont have a leak you are burning it!!!!! hell, if ya check the oil and it is going down you have a problem somewhere..........this is amazing. you are the reason we call it a "DIPSHIT stick" at my shop.
If you need any advice I just rebuilt my bottom end. Everything is still very fresh in my mind. I blew the ringlands in all my cylinders and had low compression. I wasn't burning oil though. Good luck with it and all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by code415 »</TD></TR><TR><TD CLASS="quote">So to start... my si started burning oil like 20k ago... im a full time student and work full time aswell so i havent really had a chance to take her apart to find out whats going on. 3 weeks ago im driving down the 10 freeway and i just feel a massive power loss and started decellerating dramasticly my check engine light started flashing and i knew i was fucked . i got home and did a compression check on her.. and had no compression on the # 2 cylinder
Modified by code415 at 9:10 PM 9/15/2005</TD></TR></TABLE>
drastic + dramatic = dramasticly lmao
in addition i had some pretty bad carbon build up considering that i did a decarb service only 7k ago.. im guessing what happen was since i had so much carbon on my pistons it just made my cumbustion chamber temp really high and burnt the **** out of my valves.. and my oil consumption... since it was like...a quart every 3 days for like 150 miles im guessing my oil rings were bad.. i still need to take the bottom block apart... Modified by code415 at 9:10 PM 9/15/2005</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by {PBA}Threat »</TD></TR><TR><TD CLASS="quote">drastic + dramatic = dramasticly lmao</TD></TR></TABLE>
I saw that too. Lol
I saw that too. Lol
srry i forgot to add pics was kinda late... to answer ur questions mod wise its stock. planing to build the head and go turbo with a b18b block.. just trying to finish up school first..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by code415 »</TD></TR><TR><TD CLASS="quote">srry i forgot to add pics was kinda late... to answer ur questions mod wise its stock. planing to build the head and go turbo with a b18b block.. just trying to finish up school first..</TD></TR></TABLE>
cant see pics = [
cant see pics = [
you gotta find the properties of his links and manually type them in, at least I had to.
Is that carbon build up that bad? Maybe they aren't good pics or I don't knwo what i'm talking about, just curious. Seemed like normal blackness as far as the pics I've seen on here, never taken an SI apart myself.
stupidceleb
Nov 21, 2010 09:59 AM
Natural Aspirations
41
Oct 29, 2007 11:26 AM
vtecmike1
Mar 27, 2004 07:24 PM
