Is it a bad idea to cut some of the shift linkage off?
Old Sep 15, 2005 | 06:40 PM
Junkyard2000's Avatar
Default Is it a bad idea to cut some of the shift linkage off?
Ever since i put in a new exhaust the bottom of the linkage hits the top if the piping. Im gonna be putting in a short shifter soon and it'll probly sit lower than oem. Is it ok to cut some of the linkage off(the part thats hitting). If i lower the exhaust anymore its gonna scrape everything.
Old Sep 15, 2005 | 06:45 PM
88crxsison's Avatar
Default Re: Is it a bad idea to cut some of the shift linkage off? (Junkyard2000)
are you talking about grinding out a section of your linkage? just over top of where it would hit the exaust? it doesn't seem like it would hurt if it was only like a 1/4 of the way through the linkage, but it sure wouldnt be pretty... but you gotta do what you gotta do & ****
Old Sep 15, 2005 | 07:47 PM
hopefuly it doesnt **** up my linkage
Old Sep 15, 2005 | 08:08 PM
silentdork818's Avatar
Same thing was happening to me. It was really hard to shift to 5th and reverse, but 1-4 were ok. The part that was hitting was way at the back of the linkage, but i think its just a weight so you can shift smoother. I just cut mine off like 10 mins ago, i dont think itll mess anything up.
Old Sep 15, 2005 | 08:10 PM
Default Re: Is it a bad idea to cut some of the shift linkage off? (ef four door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef four door &raquo;</TD></TR><TR><TD CLASS="quote">Same thing was happening to me. It was really hard to shift to 5th and reverse, but 1-4 were ok. The part that was hitting was way at the back of the linkage, but i think its just a weight so you can shift smoother. I just cut mine off like 10 mins ago, i dont think itll mess anything up.</TD></TR></TABLE>
did u notice any difference in shifting?
Old Sep 15, 2005 | 08:17 PM
So far no, but it was really bad before. Im sure it will be fine.
Alicali
Nov 30, 2016 09:23 AM
vtecc
Jun 1, 2015 10:53 PM
BiG Chris
15
Jun 11, 2008 05:45 PM
honda4674
Jun 24, 2006 12:45 AM
hybridbmw
Jun 24, 2002 04:15 PM
