DOHC ZC pistons?
hello all
which are the correct pistons to use on a JDM DOHC ZC engine? It's a 1991, if that makes a difference. I am getting it rebuilt and I may need to go oversize if it needs a rebore, and I want to be able to tell the machine shop guys which pistons are correct. I am hoping thet there is a USDM alternative; are the 88-89 D16A1 (Integra) pistons the same, or do they produce slightly less compression when installed?
Any info appreciated, and sorry to ask such an often discussed matter; I couldn't get any results using the search feature.
cheers
greg v
cheers
greg v
thanks for the info
after some research, I understand that P29's (88-89 Integra) and PM7's are both considered to be the correct piston for this application. If so, do they have different part numbers? And if so, why?
just curious
thanks again
greg v
just curious
thanks again
greg v
You can use any d-series piston. The bore size is 75.5mm. I bought my ZC spec. pistons from http://www.theoldone.com I haven't put them in yet cuase I just bought them but man they are awsome! Plus they got them to me in 3 days!(Which I wasen't expecting) Thumbs up to ENDYN.
its 75mm bro. if you got 75.5 pistons your gonna have to bore.
But yeah the 86-87 Teg pistons are PG6 and the 88-89 are P29
DOHC ZC PM7
but the PM7 and P29 pistons are identical in every way, not real sure why they changed the part #.
DOHC ZC PM7
SMSP
Sep 15, 2003 03:21 PM
