starting car wiring
Old Sep 15, 2005 | 04:43 PM
92hybrid+'s Avatar
Default starting car wiring
i want to make it so in order to start car it needs to be say wired to dfrost swith has to be on i ve heard of wiring it to u need to push the cruise control button how would i go about doing this
Old Sep 15, 2005 | 04:54 PM
dantastic's Avatar
Default Re: starting car wiring (92hybrid+)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hybrid+ &raquo;</TD></TR><TR><TD CLASS="quote">i want to make it so in order to start car it needs to be say wired to dfrost swith has to be on i ve heard of wiring it to u need to push the cruise control button how would i go about doing this</TD></TR></TABLE>
what?
Old Sep 15, 2005 | 05:37 PM
boostedcivicsir's Avatar
Mr. Badwrench
you need to go between the starter relay, and wire that up to the 2 pins on the defroster switch. you need a wiring diagram for that. but i dont know how it will work with a momentary switch like the def. switch.
anyone else want to chime in, id like to see how this works.
Old Sep 15, 2005 | 06:38 PM
civic_driver's Avatar
The ignition wire runs straight to the ignition switch right now... cut the wire, route it to the defrost, route a wire back to where you cut the ignition wire and you're set.
The only problem with this is if someone who knows a thing or two about electronics was to hotwire your car, they would realize what you did and simple cut the wires and connect them and start the car no problem.
You might want to run a relay from the defroster switch to the starter wires. That should be less obvious and will do the same thing. Actually, I like this method better but it's a bit more involved. Again, it's still tracable so make sure you hide those connections out of view so if you look under hood and around the starter wires it'd be tough to figure out where the connection is. This way, they wouldn't know that it goes to the defroster switch unless they follow cables through the firewall which would take too long. Or if they just cut the hack and connect the starter wires straight up.
Anyway, it's worth it for slowing down thieves.
ASR_RAMBO
Sep 4, 2009 07:41 PM
lsvtecSIrex
Audio / Security / Video
Dec 10, 2007 06:11 AM
importdude2000
Aug 8, 2007 03:31 PM
Honda Crx
Jul 17, 2006 11:07 PM
MickREXor
Oct 16, 2004 08:54 PM
