Need some TPS info please!!!
Old Feb 28, 2002 | 05:53 AM
TypeR0207's Avatar
Default Need some TPS info please!!!
OK, what can you do about a busted TPS on the throttle body (or whatever the hell it is called that is always busted on imported engines).
Which ones can I use to replace it? And what else needs to be done to get them to work??
This is on my B16 1st Gen. that I got last weekend.
Old Feb 28, 2002 | 05:55 AM
Doodoo's Avatar
Default Re: Need some TPS info please!!! (TypeR0207)
Take one off a civic or your old engine or an integra. The tough part, at least for me is adjusting it. You have to use a volt meter.
Old Feb 28, 2002 | 06:30 AM
TypeR0207's Avatar
Default Re: Need some TPS info please!!! (Doodoo)
Any more details than that?
Old Feb 28, 2002 | 08:58 AM
Doodoo's Avatar
https://honda-tech.com/zerothread?id=72766
About the middle of the page. .5 at idle and 4.5 with the throttle plate fully open. A second set of hands are usefull here.
To get it off, notch it with a dremel and use a flat head.
Old Feb 28, 2002 | 09:47 AM
turbozc2001's Avatar
or get a 88 to 91 prelude tps. im using right now for my zc dohc jdm.
Old Mar 1, 2002 | 04:20 AM
TypeR0207's Avatar
Default Re: Need some TPS info please!!! (turbozc2001)
But I don't think that the Prelude one will work since it is not a VTEC engine.
I printed out the other one, thanks!
Old Mar 1, 2002 | 07:40 AM
TypeR0207's Avatar
Default Re: Need some TPS info please!!! (beatdown88hf)
Cool, that works ......
Are there any others that will just swap right in without having to reset it???
I might end up going to a junk yard and getting a sensor from there, then re-volting it.
Would a newer VTEC equipped car be better to get the sensor from, or will it not work because it is OBD1 or 2???
[Modified by TypeR0207, 11:41 AM 3/1/2002]
Old Mar 1, 2002 | 07:44 AM
asnx6pac's Avatar
I'm using a 1st gen integra one on a D16Z6 with a 90 si ecu in a 89 std. I think has long as it plugs into the harness and fits on the TB then it'll most likely work.
Old Mar 1, 2002 | 08:30 AM
SiR Kid's Avatar
New User
Default Re: Need some TPS info please!!! (asnx6pac)
As long as it's off of an intake manifold that uses 4 injectors, it'll work.
bad71chevy
May 14, 2013 02:51 AM
Thegreenlude
Dec 23, 2008 11:38 PM
91_HB
Jun 14, 2005 06:07 AM
Turck
Oct 21, 2004 04:42 AM
Traction
14
Aug 23, 2004 11:12 PM
