D16 Engine Rebuild
Hello I currently own a Honda Del Sol 1.6 Liter SoHC. I want to rebuild my engine but also add more HP on to the engine while rebuilding the engine. SO does anyone have a list of parts or websites that would help me to get to my goal. THanks alot.
-Kiseki
-Kiseki
Cruise http://www.d-series.org. That's pretty much the best place for info on the D-series motors. I'm currently rebuilding a D16Y8 with D16A6 pistons to bump the compression a point or so, and got alot of info from that site. Good luck.
B96v6
B96v6
i'd post this in the all motor section. the a6 pistons would give you around 10.5 c/r if you went with the p29's (d16a1 1st gen integra) they would yield over 12.5 c/r. both can be found pretty inexpensively as well.
petr0lb0mb
Engine Machining & Assembly
Nov 1, 2022 01:38 PM
whitebluepearlsol
Dec 14, 2005 12:12 PM
