OBD1 GSR bottomend into a 00 SI question
Old Sep 15, 2005 | 01:08 PM
1337 Si's Avatar
Default OBD1 GSR bottomend into a 00 SI question
OK I picked up an OBD1 95 GSR bottomend a month ago from another member of Honda-Tech. I completely did not relaize that it did not have acrank angle sensor ( I wasn't really thinking). My question is this. I have an 00 b16a2 in my garage as well that is toast, but it has a crank angle sensor. Can I swap this onto the b18c along with the other proper accessories? I am jsut trying to be cost efficient here. If this will not work Just let me know. or what all else is involved in swapping this over.
Old Sep 15, 2005 | 01:23 PM
johnnylaw's Avatar
Default Re: OBD1 GSR bottomend into a 00 SI question (1337 Si)
that should work no problem
Old Sep 15, 2005 | 07:38 PM
1337 Si's Avatar
Default Re: OBD1 GSR bottomend into a 00 SI question (gsrturbojohn)
Ok I did not know if they were completely differnt parts or what.
Old Sep 15, 2005 | 07:41 PM
hatchi's Avatar
yes you can transfer it over and it will be fine
Old Sep 16, 2005 | 07:20 AM
1337 Si's Avatar
Default Re: OBD1 GSR bottomend into a 00 SI question (hatchi)
Awesome saves me some time and money.
Old Sep 16, 2005 | 07:32 AM
ABK's Avatar
ABK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1337 Si &raquo;</TD></TR><TR><TD CLASS="quote">Awesome saves me some time and money.</TD></TR></TABLE>
NO
if the motor is gsr motor is obdI you will need to swap the whole oil pump assembly on it, but I wouldn't use the one of the used motor, non the less blown.
Old Sep 16, 2005 | 08:02 AM
1337 Si's Avatar
Default Re: OBD1 GSR bottomend into a 00 SI question (ABK)
Right, the bottomend is getting built up by Earl so I am sure I can relate what I want to do with it to him. Thanks for the insight bro, much appreciated.
tannerLSt
Jul 26, 2008 06:21 AM
DOHCgarage919
Feb 5, 2007 01:35 PM
NA JDM GSR
Jul 8, 2005 01:25 PM
TypeGSR196
Oct 21, 2004 05:33 AM
