Motor mounts need opinions
Old Sep 15, 2005 | 01:05 PM
messeduprex's Avatar
Default Motor mounts need opinions
ok my motor mounts are shot to **** i keep cracking downpipes and my shift linkage is busted because of it no i looked at the es inserts but it only comes with two mounts my other option is 3m window weld should i do both? or does anyone else have a cheap solution
Old Sep 15, 2005 | 01:19 PM
Tyson's Avatar
Default Re: Motor mounts need opinions (messeduprex)
i'm happy with my cheap solution.
https://honda-tech.com/zerothread?id=1124506
Old Sep 15, 2005 | 01:20 PM
vegaskurt's Avatar
prothane makes inserts for all 4 mounts. The window weld and some curing time I hear works good. Or just go to honda and buy new ones.
Someone else did a thread on using some thick wall rubber tubing, then just cutting pieces of it to use as inserts. Cant find the link.
...Guess we posted at the same time...
Old Sep 15, 2005 | 01:21 PM
Tyson's Avatar
Default Re: Motor mounts need opinions (vegaskurt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vegaskurt &raquo;</TD></TR><TR><TD CLASS="quote">Someone else did a thread on using some thick wall rubber tubing, then just cutting pieces of it to use as inserts. Cant find the link.</TD></TR></TABLE>
ive done this twice now, on both crx's i own. same great results both times. no wheel hop.
EduardoDC5
16
Jan 8, 2009 10:52 AM
1994delsolLS
15
Sep 27, 2008 09:28 AM
BLUE EH3
16
Mar 19, 2007 09:20 AM
Dumped DB2
Aug 2, 2005 11:00 AM
dsadas89das78934
23
Oct 23, 2003 11:13 AM
