motor mounts
motor mounts
i have a 94 del sol with an ls motor and the motor mounts are shot i bought the car with the swap what motor mounts do i get could someone send me a link or something?
1 Post
Re: motor mounts (1994delsolLS)
How much do you wanna spend??
You can get inserts from Energy for about $20 and have stock ones pressed out, and those pressed in.. Or you can pick up a set of hasports for about $300 + or Avids for a bit less.
IF your mounts arent THAT bad you can use a urethane fill but I wouldnt recommend this if your mounts are in fact "shot" as you say they are...
1 Post
Re: motor mounts (Just Me Ek5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Just Me Ek5 »</TD></TR><TR><TD CLASS="quote">get some engery suspension inserts or innovative mounts are kinda cheap.</TD></TR></TABLE>
Innovative are cheaper too, i did forget about those. I have the A/T to M/T conversion mount and it seems to work fine for me.
1 Post
Re: motor mounts (scbmx87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scbmx87 »</TD></TR><TR><TD CLASS="quote">I'll sell you OEM b series mounts for $75 shipped. </TD></TR></TABLE>
Buy those ^^^^^ and urethane fill.... $100 solid mounts ftw!!!!!!
Re: motor mounts (Thateguhate)
like there bad to the point were i step on the gas to hard and all you hear is the motor mounts knock its horrible and it pisses me off and what the main question is is what mounts do i buy? like do i need specific ones or are there special ones for swaps?
Pretty much all the major mount companies will have "off the shelf" setups for your car.
You don't need to press anything out of the stock mounts if you use the ES inserts, they fit in around the stock insides, but they're only for the rear and lower mounts.
Personally, I use Hasport mounts and I've never been anything but happy with them. The price point may be a bit more than some other mounts (and way more than the inserts), but the quality is top notch and the customer service is excellent.
Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">Pretty much all the major mount companies will have "off the shelf" setups for your car.
Personally, I use Hasport mounts and I've never been anything but happy with them. The price point may be a bit more than some other mounts (and way more than the inserts), but the quality is top notch and the customer service is excellent.</TD></TR></TABLE>
i went to the website and i got confused there are like 2 or 3 diff ones how do i know wich ones will fit exactly?
Re: (wdissident)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wdissident »</TD></TR><TR><TD CLASS="quote">HOCKEY PUCK. </TD></TR></TABLE>
Huh?
Huh?
First you need to see what LS you have. Read the Block its either a B18A1 or B18B1. There both really the same although if im not mistaken the A1 has only two bolt ups for the motor mount on the drivers side by the timeing cover. The B1 has 3 holes as a bolt up for the most part it does change depending on who owned the motor or simply what yr it is. After that just go to the website you choose to get your mounts from and look up Del Sols w/ a B series swap then just match up the picture and see if the drivers side is the one you need. The only other thing you have to keep in mind is if you have a cable or hydro tranny. Thats pretty much it. Check these sites out.
http://www.innovativemounts.com/default.asp OR
http://www.hasport.com/products/mounts.htm You will need EGB1 for cable tranny or EGSTK
Re: motor mounts (Manny1987)
i have no idea if its cable or hydro the guy i bought it from said its a gsr tranny how would i find out wich one it is
Look in front of the tranny by the radiator (passenger side)
Hydro would have this (slave Cylinder)
http://www.theautochannel.com/...o.jpg
Heres a similar layout of the whole thing if you dont have the slave cylinder like this one then its cable driven.
http://www.slhondaparts.com/im...9.jpg
Re: (Kendall)
Hasport does have excellent customer service, they sent me the black, i think rated 64, inserts with my mount when i ordered the red, i think 94?, and then just sent me the red mount after i called and told them about it. So I have the black ones sitting in my garage=].
D16SohcVtec
08-12-2008 08:03 AM
birds_sol_94
11
08-01-2006 02:08 PM
h-spec_crx
04-30-2003 01:03 PM
