Auto 1996 B18B into auto 1993 Del Sol
Old Sep 15, 2005 | 11:36 AM
D-Rob's Avatar
Default Auto 1996 B18B into auto 1993 Del Sol
Alright, here's the deal.
Just got an automatic '93 Del Slow and it's (as the name implies) slower than ****.
I have the opportunity to buy a wrecked 1996 Integra LS for two hundred dollars.
My question is, would I simply need to swap over the complete engine harness from the ECU forward for this to work properly?
I realize I'm trying to put an OBD2 motor into and OBD1 car.
Any help is greatly appreciated.
- Derek
Old Sep 16, 2005 | 10:08 PM
sir2sol's Avatar
Default Re: Auto 1996 B18B into auto 1993 Del Sol (D-Rob)
as long as you have the ecu to the ls, all that you would have to do is run a wire for the knock sensor. and even if there is more than that it might be easier to get a obd2 to obd1 harness.
Old Sep 16, 2005 | 11:48 PM
The Clash's Avatar
Default Re: Auto 1996 B18B into auto 1993 Del Sol (sir2sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir2sol &raquo;</TD></TR><TR><TD CLASS="quote">as long as you have the ecu to the ls, all that you would have to do is run a wire for the knock sensor. and even if there is more than that it might be easier to get a obd2 to obd1 harness.</TD></TR></TABLE>
There is no knock sensor on an LS. The LS ECU won't work since it's OBD2 unless you get an OBD1 to OBD2 adapter harness and do some wiring which is pointless.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">I realize I'm trying to put an OBD2 motor into and OBD1 car.</TD></TR></TABLE>
Just get a P74 or P75 OBD1 LS auto ECU and it's plug and play. You can use the LS engine harness and it'll plug right into the Del Sol's cabin harness - OBD2 Integra harnesses match up to OBD1 Civic's.
89accordvtec?
Mar 28, 2013 04:09 AM
89accordvtec?
Mar 27, 2013 06:15 PM
vinnnocc
Jan 12, 2013 05:38 AM
jaydmej1
Mar 22, 2004 09:09 AM
