b18c5 into EK
Old Sep 15, 2005 | 09:17 AM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
Default b18c5 into EK
i just bought a 98 cw itr. i have the complete car.
i also own a 97 civic ex. what do i need besides mounts for this swap?
i have the p73 itr ecu .and since the itr is a 98 and my coupe is a 97 both obd2 i shouldnt have wiring problems? what <a style='text-decoration: none; border-bottom: 3px double;' href="http://www.serverlogic3.com/lm/rtl3.asp?si=9&k=wire%20harness" onmouseover="window.status='wire harness'; return true;" onmouseout="window.status=''; return true;">wire harness</a> to use also? shift linkage and mounts? please any comments will be good.im new to the EK chasis...i just always had eg's....thanks
Modified by honduhh at 2:47 PM 10/3/2005
Old Sep 15, 2005 | 09:59 AM
_HANS's Avatar
Default Re: b18c5 into EK (honduhh)
BUMP!!!!!!!!!!!!!
Old Sep 15, 2005 | 10:00 AM
RedEK9's Avatar
search mang, let me see if I could get you a link
Old Sep 15, 2005 | 10:16 AM
_HANS's Avatar
Default Re: b18c5 into EK (RedEK9)
i searched
Old Sep 15, 2005 | 05:54 PM
_HANS's Avatar
bump this..
Old Sep 15, 2005 | 06:03 PM
koatic's Avatar
shift linkage and axles.. the itr has a half shaft axle.. your ex does not.
I am not sure about the wiring though.. sorry.
Old Sep 15, 2005 | 08:00 PM
_HANS's Avatar
Default Re: b18c5 into EK (koatic)
more info pleaseee
Old Sep 15, 2005 | 08:06 PM
SikBubble20's Avatar
i think you can use stock mounts unless needed
Old Sep 15, 2005 | 08:14 PM
_HANS's Avatar
Default Re: b18c5 into EK (SikBubble20)
ttt
Old Sep 15, 2005 | 08:28 PM
ek-to-tha-max's Avatar
LISTEN TO EVERYTHING IM GONNA SAY because its CORRECT and you WILL need it
HERES THE INFO
you have a 97 EX and its obd2a
you have a 98 ITR and its obd2a
your VERY LUCKY
96-99 integra is obd2a, 00-01 integra is obd2b
96-98 civic is obd2a, 99-00 civic is obd2b
see the difference?
wiring would not be a problem, just plug your single cam EX harness onto the ITR motor and your good. you just have to extend your crank sensor plug and o2 sensor plug. not a problem at ALL.
if you got the whole car, use everything from it (these guys^^^^ up there dont know what theyre talkin about.. halfshaft???). take the axles, halfshaft, ecu. take the 5lug too. all you need for this motor swap is SI mounts(2 main ones) and SI shift linkage. the ITR p73 ecu will bolt directly onto your EX harness, you can try it right now, see how it runs.
i have a 97 like you. so i know what im talkin bout. let me know if you get stuck
Old Sep 15, 2005 | 08:48 PM
_HANS's Avatar
Default Re: b18c5 into EK (ek-to-tha-max)
ek-to-tha-max--- thanks alot man.you cleared alot up for me
i know all bout that obd junk i just didnt know if my stock harness will work on the dohc dizzy and all.just get SI rear tranny mount and timing belt mount? how will i know which ones the crank sensor to extend? will i have a check engine light?
any more info..im me on aol- ihateyounj
Old Sep 16, 2005 | 01:28 AM
FuNkDrSpOt's Avatar
Ya, heres all the info you need here:
its not exactly plug and play but its close.
http://www.phear7imports.net/trey/6gen/
Old Sep 16, 2005 | 06:26 AM
_HANS's Avatar
Default Re: b18c5 into EK (FuNkDrSpOt)
i thought it would be plug and play? some people say since ill be using the p73 ecu i will have a E-MOBILIZER? whats that?
Old Sep 16, 2005 | 11:17 AM
_HANS's Avatar
BUMPP THIS UP!!
Old Sep 16, 2005 | 11:28 AM
98DC2-ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honduhh &raquo;</TD></TR><TR><TD CLASS="quote">i thought it would be plug and play? some people say since ill be using the p73 ecu i will have a E-MOBILIZER? whats that?</TD></TR></TABLE>
'97-'98 ITR's don't have IMM in the ECU. '00-'01 are the ones with the IMM.
Old Sep 16, 2005 | 02:25 PM
FuNkDrSpOt's Avatar
did you not just read the link i put on here? what else is there to bump? READ IT!
Old Sep 18, 2005 | 03:52 PM
_HANS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt &raquo;</TD></TR><TR><TD CLASS="quote">did you not just read the link i put on here? what else is there to bump? READ IT!</TD></TR></TABLE>
that thread does nothing for me
Old Sep 18, 2005 | 04:01 PM
mdd's Avatar
mdd
i was wondering if you get a itr motor and dont have 5 lug will you have axle fitment problems?
Old Sep 20, 2005 | 04:41 PM
_HANS's Avatar
Default Re: b18c5 into EK (mdd)
axle problems?
Old Sep 20, 2005 | 09:35 PM
akteamster's Avatar
bump becuase i am doing the same swap in my 96 dx in a week or two
Old Sep 20, 2005 | 10:23 PM
mdd's Avatar
mdd
Default Re: b18c5 into EK (akteamster)
like problems getting the 36 mm into the 32 mm usdm hubs
Old Sep 20, 2005 | 11:44 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
ONLY the JDM ITR uses 36mm hub/axles. USDM does NOT. You can use any b-series axles and you will be fine.
Old Sep 21, 2005 | 12:35 AM
BbOi0420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek-to-tha-max &raquo;</TD></TR><TR><TD CLASS="quote">LISTEN TO EVERYTHING IM GONNA SAY because its CORRECT and you WILL need it
HERES THE INFO
your VERY LUCKY
see the difference?
i have a 97 like you. so i know what im talkin bout. let me know if you get stuck</TD></TR></TABLE>
hypothetical question, what if it was a ob2a non vtec ek, would a obd2a ls motor work as plug and play like above mentioned? sorry dont mean to hijack.
Old Sep 21, 2005 | 09:46 AM
Earthworm Jim's Avatar
PM <FONT COLOR="BLUE">B18C5-EH2</FONT>
Old Sep 21, 2005 | 11:23 AM
_HANS's Avatar
Default Re: b18c5 into EK (Enigma_Performance1)
BUMP!!
