Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
TL TRANSMISSION OIL REFILL
Old Sep 15, 2005 | 08:47 AM
HONDA RR's Avatar
Default TL TRANSMISSION OIL REFILL
Where do you refill the transmission oil on a 03 3.2 tl types? I hope its not the same place where the dipstick goes because its hard to find a funnle that narrow.
Old Nov 17, 2005 | 01:22 PM
iam7head's Avatar
Default Re: TL TRANSMISSION OIL REFILL (HONDA RR)
yep
Old Nov 21, 2005 | 04:04 PM
Pure Adrenaline's Avatar
If you look toward the back of the transmission (the firewall side), you will see a bolt on top of the casing. That's the fill hole. Much easier than the dipstick hole. If you have the oil jet kit installed per the recall, then you just have to remove the bolt holding the black metal bracket down. Then the jet will slide right out and you can fill the fluid through that. If you don't have the oil jet kit, then it'll just be a bolt. It's on there HARD so you will have to use some leverage.
Remember, 3 quarts per drain, so refill 3 quarts. Acura recommends 3 drain/refill process, so buy 9 quarts of transmission fluid. Remember to drive the car between each drain/refill to lock and unlock the torque converter (happens at approximately 40-45 mph) so that the fluid gets circulated all the way.
Old Nov 23, 2005 | 06:06 AM
HONDA RR's Avatar
Default Re: (Pure Adrenaline)
Hey thanks a lot i will check that out.
skwigelf
20
Jul 9, 2014 05:30 AM
kingdeadguy
Feb 29, 2012 04:39 PM
3lo
12
Oct 17, 2007 05:59 PM
H 20two 4 Me
Aug 24, 2006 02:46 PM
teewhy55
13
Dec 13, 2004 11:17 AM
