lsd tranny use a different type of mtf?
don't units such as the Kaaz one, require its own fluid? i'm not quite sure about the Quaiffe ones though.
[Modified by xlr8 si, 2:04 AM 2/28/2002]
Clutch type LSD's do require a bit heavier gear oil than regular torsen or gear type LSD's. YOu can use regular fluid but heavier fluid is recommended.
GM has a "really" stinky tube of additive that a friend used on his "clutched" LSD
Will
YATCHI
Transmission & Drivetrain
May 11, 2013 02:39 AM
JDMcivicSiRII
Jul 28, 2004 12:07 PM
