act clutch problems searched
Old Sep 14, 2005 | 11:01 PM
sohctodohc's Avatar
Default act clutch problems searched
well i installed my act HD PP and SS disk with there prolite flywheel. and noticed after prob 500 miles something was chattering horribly. well it turns out it is the throw out bearing. has neone had problems with the bearing act sends with the kit???? are you supose to grease the bearing??? when i pull the tranny of should i expect a fucked up bearing??? and on another note has neone heard of carbon fiber synchros??? if so can someone give me a website to them??? thanks
o this is on a ej1
Old Sep 14, 2005 | 11:36 PM
sohctodohc's Avatar
Default Re: act clutch problems searched (sohctodohc)
i know someone has had this problem
Old Sep 15, 2005 | 01:15 AM
siregcivic's Avatar
i have a built act stage 2... well hd pressure plate and street flywheel... or somethin like that.. well anyway.. my **** grabs hard and its stiff.. and if i let it out kinda quick it jerks you hardcore.. and if i try to let it out slow it chatters.. maybe ur having the same problem
Old Sep 15, 2005 | 04:05 AM
JDMlyfestyle's Avatar
Clutch chatter can be sometimes a common problem. I know alot of 3000GT and DSM guys have the same problem. but its just a little chatter as long as the clutch engages good then u should be ok..
but i do recomend putting some oil on the throw out bearing.
Old Sep 16, 2005 | 12:05 AM
sohctodohc's Avatar
Default Re: (JDMlyfestyle)
well the pedal doesnt fill near as stiff as it did at first that could be me getting use to it tho. it chatters constantly it evenm whines while im slowly taking off in first.
Old Sep 16, 2005 | 12:20 AM
ROK801's Avatar
Default Re: (sohctodohc)
not to point out the obvious, but have you tried letting it out fast to see if the same thing happens?
Old Sep 18, 2005 | 05:43 PM
sohctodohc's Avatar
Default Re: (ROK801)
well i thyink i figured it out. i think it is the throw out bearing. has anyone had problems with the throw out bearing act sends with the kit??? i think im gonna rip it apart and try a honda throw out bearing. that or we forgot to lube the bearing where it slides onto the shaft. does it matter wut kinda grease you lube it with???
Old Sep 19, 2005 | 08:01 AM
sohctodohc's Avatar
i know someone has used the act throw out bearing
Old Sep 19, 2005 | 09:20 AM
sohctodohc's Avatar
ttt
Old Sep 19, 2005 | 10:26 AM
siregcivic's Avatar
you are supposed to grease the shaft of the tranny that the throwout slides on.. not alot just a little cover.. i havent had any problems with my act throwout at all
Old Sep 19, 2005 | 10:50 AM
Marauder's Avatar
Default Re: (siregcivic)
Use white lithium grease over the whole input shaft on the tranny and put some grease on the inside diameter of the TOB.
Old Sep 19, 2005 | 11:15 AM
wwang924's Avatar
Default Re: (Marauder)
i used a lil valvoline synthetic blend bearing grease on that.
Old Sep 22, 2005 | 12:12 AM
sohctodohc's Avatar
Default Re: (wwang924)
alright anotha ? since i installed the clutch to now i have noticed that when releasing the pedal it takes longer for it grab...you almost have to release it to where the play in the pedal is??? wut could that be? and what causes the springs in the disk to break??? that happened in my last couple clutches??? haha last what should i look at on the pp and disk for wear or irregular wear???
Old Sep 22, 2005 | 07:01 AM
sohctodohc's Avatar
ttt
Old Sep 22, 2005 | 07:57 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohctodohc &raquo;</TD></TR><TR><TD CLASS="quote">alright anotha ? since i installed the clutch to now i have noticed that when releasing the pedal it takes longer for it grab...you almost have to release it to where the play in the pedal is??? wut could that be? and what causes the springs in the disk to break??? that happened in my last couple clutches??? haha last what should i look at on the pp and disk for wear or irregular wear???</TD></TR></TABLE>
You can adjust where the clutch grabs by adjusting the bolt on the back of your clutch pedal. Twist it in or out to get it to grab where you want it.
I haven't had any problems with my ACT clutch kit at all. The throw out bearing comes pre-greased, but, like stated before, you have to grease up the input shaft.
I don't think the throw out bearing would cause the symptoms you are describing, but I could be wrong.
How many miles did you say are on the clutch? Did you break it in properly?
Have you tried revving it up and letting the clutch out slowly? Sometimes that takes care of any chattering problems that may occur durring the break in period.
Old Sep 22, 2005 | 08:03 AM
sohctodohc's Avatar
Default Re: (EJ1 wilcox)
theres prob. over a couple thousand miles on the clutch haha i didnt know there was a break in period. it has to be the throw out bearing unless its the disk or pp i dunno also what causes the springs in the disk to break??? that happened in my last couple clutches??? haha last what should i look at on the pp and disk for wear or irregular wear???
Old Sep 22, 2005 | 08:11 AM
EJ1 wilcox's Avatar
If the springs on your ACT clutch are broken, shoot me a PM and I'll contact my ACT rep, that is definately a product defect.
When you take the pp out, look for irregular wear patterns, scratches, or hot spots.
The disk shouldn't be chipped or cracked, and the springs should be in good shape.
Old Sep 23, 2005 | 09:42 AM
sohctodohc's Avatar
alright i will be taking it apart this weekend ill let you know. two of the 3 or 4 springs on my last clutch exploded in the disk. but ill let you know if there is any irregular wear on the pp or disk and the springs.
Old Sep 23, 2005 | 10:43 AM
siregcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohctodohc &raquo;</TD></TR><TR><TD CLASS="quote">two of the 3 or 4 springs on my last clutch exploded in the disk.</TD></TR></TABLE>
that happened to my clutch... well the stockone... when i took it out to replace it with the act clutch.. right when i pulled the disc off one of the springs fell off
Old Sep 25, 2005 | 11:06 PM
sohctodohc's Avatar
welp i didnt make it around to taking it apart this weekend. but i noticed another thing when i put it into second while going 30 or 40 it whines and then when i let out on the clutch and the revs go up it makes this high screatching sounds its nasty sounding i dont no how to explain it. hopefully its not a synchro. and hopefully next weekend i can get round to taking it apart
Old Sep 26, 2005 | 09:36 AM
sohctodohc's Avatar
ttt for more help
Old Sep 26, 2005 | 09:54 AM
ThatsMyEG's Avatar
That act bearing they send you in the clutch kit is the same one autozone uses. My friend use to always have a weird sound like that everytime he started up his car/shifted, he never tryed to fix it and he never had a problem..
Old Sep 26, 2005 | 12:22 PM
sohctodohc's Avatar
Default Re: (ThatsMyEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatsMyEG &raquo;</TD></TR><TR><TD CLASS="quote">That act bearing they send you in the clutch kit is the same one autozone uses. My friend use to always have a weird sound like that everytime he started up his car/shifted, he never tryed to fix it and he never had a problem..</TD></TR></TABLE>
but this isnt just when i turn the car on its at all times besides when the pedal is down on the floor and its really really loud. i noticed today when i shifted from 2nd to 3rd its not pulling near as hard and when i use to shift hard from 2nd to 3rd it would pull hards and squeek at me now it doesnt pull near as hard and it doesnt squeek.....ttt for a poor man and maybe a fucked clutch.
Old Sep 28, 2005 | 09:04 AM
sohctodohc's Avatar
ttt
Old Sep 28, 2005 | 10:06 PM
sohctodohc's Avatar
ttt cmon honda guru's i know you have some advice for me.
