Heavily street-tuned B20VTEC engine - need some advice
Old Sep 14, 2005 | 10:11 PM
turbopanda's Avatar
Default Heavily street-tuned B20VTEC engine - need some advice
Hey people
I'm helping a friend build a B20VTEC EG6. It'll be running with ~12.6:1 C/R, and have a fully worked head. Will be revved high when used for racing - bottom end has been worked on and is ok for 8.5-9k redline (it's a daily driven street car).
My original plan was for him to go with ordinary Skunk2 Stage 2 cams, and Skunk2 intake manifold, however, after a little research, I've noticed that there's a lot of other newer products on the market now, like intake manifolds from Blox and Edelbrock, as well as new cams from Buddy Club, Rocket Motorsports, and the Skunk2 Pro series.
Can anyone help me lead my friend into the right direction? What would work real well with the setup i've briefly described? Which cams + intake manifold?
Also, which intake manifold has the largest plennum? We have a 70mm throttle body which we would like to bolt onto the manifold..
Thanks
Old Sep 15, 2005 | 03:36 AM
blackhatchb20's Avatar
Default Re: Heavily street-tuned B20VTEC engine - need some advice (turbopanda)
buddy club 4's either that or Jun 3's - those are the cams that i have known to make the most power
for my *mild* b20/vtec i'll eventually be running buddy club 3+'s when i can afford 'em
Old Sep 15, 2005 | 10:12 AM
DonF's Avatar
Default Re: Heavily street-tuned B20VTEC engine - need some advice (blackhatchb20)
What other cams did you dyno the BC4's and June 3's against?
Old Sep 15, 2005 | 02:10 PM
Used2beAb16's Avatar
buddy club 4's most power??
Old Sep 15, 2005 | 03:13 PM
DonF's Avatar
Default Re: Heavily street-tuned B20VTEC engine - need some advice (Used2beAb16)
Ask Blackhatch20, he has seemed to have dynoed alot of cams.
Old Sep 17, 2005 | 06:40 AM
turbopanda's Avatar
Old Sep 17, 2005 | 07:28 AM
turbociv's Avatar
im not sure about the cams, since i run crower 63403's and put down 226 untuned but i know that there are better cams out there since the crowers are kinda small with not alot of overlap. for anything 2.0liter and up the edelbrock victor x manifold seems to make the best power.
donF has done extensive cam testing along with Tbone either they can give a suggestion or you can do a search.
Old Sep 17, 2005 | 11:11 PM
turbopanda's Avatar
Default Re: (turbociv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociv &raquo;</TD></TR><TR><TD CLASS="quote">donF has done extensive cam testing along with Tbone either they can give a suggestion or you can do a search.</TD></TR></TABLE>
If any of these guys are reading this thread, can you please give me your opinions? Thanks
Old Sep 18, 2005 | 07:49 PM
Default Re: (turbopanda)
search, there is alot of dyno's on different cams, buddy club seem to make the most top end, but skunk 2 pro1's seem to make more low end...
Old Sep 18, 2005 | 07:56 PM
swaytec360's Avatar
Default Re: (blackhatchb20)
id look at the new skunk prolines, m22s, or bc4s all have made great power across the whole powerband
monster_c
14
Mar 21, 2012 08:46 PM
MansuDC2
Aug 2, 2005 05:20 PM
killablaze
Jan 28, 2005 08:47 PM
b18cInside
Jan 7, 2003 09:26 AM
Dirty GS-R
Sep 26, 2001 04:35 PM
