(FI gurus) having problem under load at low RPM/traffic creaping
Old Sep 14, 2005 | 08:27 PM
fastrunner's Avatar
Default (FI gurus) having problem under load at low RPM/traffic creaping
As the title says: When I take off from a dig and feather my clutch I can see the RPM's bounce, not erraticly but enough to see it on the tach and hear it in the car, about 2-300 rpm's. When I give it more gas it steadies out and maintains a steady RPM, It seems to be related to the position of the throttle as in the same effect in second and third if my foot is depressed the same amount on the gas pedal.
Details:
b16A2 converted to obd1
P28
GM 3 bar map
Hondata s100 w/boost opt.
t3/t4
high flow pump
Stock FPR
990 injectors
How do I remedy this. Its not the IACV, the car idles fine with my foot off the gas no idle hunting there.
Its not a vacuum leak, I searched and checked all connections and hoses, and I hit full boost @ 11psi with good throttle response.
My only thought is that I need to modify my FPR to allow more gas to return to the tank at low load? anybody else got anything on this, If Im wrong please speak on it and back your arguement with fact.
The car runs like a bat outta hell, no complaints just when trying to creap in traffic it lurches due to this problem, the problem is only there under slight load if im stopped its fine, some FI guru come to the rescue.
Old Sep 14, 2005 | 08:49 PM
fastrunner's Avatar
Default Re: (FI gurus) having problem under load at low RPM/traffic creaping (fastrunner)
bump for an answer please.
Old Sep 14, 2005 | 09:00 PM
2k.civic.si's Avatar
"seems to be related to the position of the throttle as in the same effect in second and third if my foot is depressed the same amount on the gas pedal."
check your tps sensor
Old Sep 14, 2005 | 09:11 PM
fastrunner's Avatar
Default Re: (FI gurus) having problem under load at low RPM/traffic creaping (2k.civic.si)
checkin helms as we speak
Old Sep 15, 2005 | 06:25 PM
fastrunner's Avatar
ok its not the TPS, what I have discovered is it only happens under vacuum, like 17 to 15 hg/in on the boost gauge.
Old Sep 15, 2005 | 08:22 PM
Sprockets's Avatar
I'm going to take a guess and say it's a tuning issue. I have some strange anomalies with my tune. The drivability varies, and it's really quite annoying.
Old Sep 22, 2005 | 05:11 PM
fastrunner's Avatar
Default Re: (FI gurus) having problem under load at low RPM/traffic creaping (USE2B16A)
yah maybe a tuning issue???
Old Sep 22, 2005 | 08:57 PM
topspeed's Avatar
same **** with me i think its my timing, i tweaked the afr's under vacum and it seemed better but i still get what your describe just not as bad no more.
Old Sep 23, 2005 | 11:49 PM
Default Re: (topspeed)
maybe try another map sensor.....but the tuning could the problem....
blue2006civic
Honda Civic (2006 - 2015)
Jun 17, 2015 06:13 PM
bigred850
Engine Management and Tuning
Sep 24, 2011 03:31 PM
eM1<3
13
Jan 27, 2010 03:47 PM
twkdCD595
May 25, 2005 08:04 PM
jdm169
Feb 9, 2003 07:24 AM
