DC 4-1 B16 headers fit my 92 GSR???
Old Sep 14, 2005 | 08:14 PM
92integraVTECgsr's Avatar
Default DC 4-1 B16 headers fit my 92 GSR???
would DC 4-1 Headers for a B16 fit my 92 integra B17?? i know they will fit, but im worried about clearance issues? are there any with the Cross member? will they slide right in?
anyone got any pics???
Old Sep 14, 2005 | 08:32 PM
Default Re: DC 4-1 B16 headers fit my 92 GSR??? (Subawho)
krisgt2@hotmail.com
how much cutting? do i need to cut? **** i dont want to cut
Old Sep 14, 2005 | 08:43 PM
cut and weld.. oh dear.. why does fun come with work..
Old Sep 15, 2005 | 10:47 AM
Default Re: DC 4-1 B16 headers fit my 92 GSR??? (92integraVTECgsr)
anyone make them fit without cutting the cross member??
Old Sep 15, 2005 | 10:57 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Subawho &raquo;</TD></TR><TR><TD CLASS="quote">yea, i have a 91 teg. i got picks, you have to cut a little in the cross member. give me ur addy and i will send u the pics.</TD></TR></TABLE>
ok your response does not answer his question, he has a 92 GSR, you have a 91 with a swap
Old Sep 22, 2005 | 06:07 PM
HondaCivicSiR1's Avatar
Default Re: DC 4-1 B16 headers fit my 92 GSR??? (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">
ok your response does not answer his question, he has a 92 GSR, you have a 91 with a swap</TD></TR></TABLE> actully nieter of you answerd his question and i would like to know also does the b17a have larger deck height then a b16a and why would a da need the cross member cut out? doesn't have more room in the engine bay thena civic?
Old Sep 23, 2005 | 06:53 AM
temp's Avatar
Default Re: DC 4-1 B16 headers fit my 92 GSR??? (HondaCivicSiR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 &raquo;</TD></TR><TR><TD CLASS="quote">
actully nieter of you answerd his question and i would like to know also does the b17a have larger deck height then a b16a and why would a da need the cross member cut out? doesn't have more room in the engine bay thena civic?</TD></TR></TABLE>
no, the deck height of the b17a and the b16a is identical, you dont need to cut the x-member from what i have seen
Old Sep 23, 2005 | 08:17 AM
projectTeG's Avatar
are yal talking about cutting the cross bar thing under the engin? because db2 didnt come with them. i have a b16 header on my 91 rs with a 93 engine and it rubbed the cross bar slightly....so i took it out. BTW the deck heights are the same seing the b17 is just a stroked b16. the header should bolt up fine all you have to worry abour is how the outlet of the headers going to bolt to the exhaust. i had to angle the connection part of my exhaust alil bit so it would bolt up....becuse my header had a angle for some odd reason.
Old Sep 23, 2005 | 08:34 AM
temp's Avatar
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">are yal talking about cutting the cross bar thing under the engin? because db2 didnt come with them. i have a b16 header on my 91 rs with a 93 engine and it rubbed the cross bar slightly....so i took it out. BTW the deck heights are the same seing the b17 is just a stroked b16. the header should bolt up fine all you have to worry abour is how the outlet of the headers going to bolt to the exhaust. i had to angle the connection part of my exhaust alil bit so it would bolt up....becuse my header had a angle for some odd reason.</TD></TR></TABLE>
no, the cross member and the cross bar are 2 different things
Old Sep 23, 2005 | 08:37 AM
projectTeG's Avatar
Default Re: (temp)
no, the cross member and the cross bar are 2 different things</TD></TR></TABLE>
oh ok excuse the slowness i just woke up, i thought i saw 4-2-1. but yea for a 4-1 header you need to either notch it so the header can fit of hit it with a BFH like someone did with my car before i had it.
it here a good pic i found on g2ic.
Old Sep 23, 2005 | 08:59 AM
temp's Avatar
its going to really depend on the header, as you can see from the link that is a B20 (with VTEC?) w/ a header for who knows what application on there.
EDIT: that also looks like a swapped motor and not a STOCK GSR as in the first pic you can see where the cross bar was removed
Old Sep 23, 2005 | 09:20 AM
projectTeG's Avatar
Default Re: (temp)
just a reference ....not all of us can be blessed with owning the db2
Old Sep 23, 2005 | 09:33 AM
thats a good pic.. i dont think i want to do any cutting or removing anything.. i think im gonna stick to the DC 4-2-1. It's supposed to be the best overall header.
Old Sep 23, 2005 | 10:24 AM
temp's Avatar
Default Re: (92integraVTECgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">thats a good pic.. i dont think i want to do any cutting or removing anything.. i think im gonna stick to the DC 4-2-1. It's supposed to be the best overall header. </TD></TR></TABLE>
depends on your goals and powerband
milligan41088
Dec 10, 2006 05:27 PM
milligan41088
Apr 26, 2006 07:36 PM
smikeL
Nov 24, 2005 11:12 PM
turbociv910
Oct 27, 2005 12:47 PM
gaydm
Feb 24, 2005 06:49 PM
