Need help identifying wires, etc.
Old Sep 14, 2005 | 07:51 PM
SiMateoAko's Avatar
Default Need help identifying wires, etc.
So this is my first engine swap. I'm thrilled as all can be. However, since i've never done this ebfore, i want to make sure I'm doing it right. So I've posted a few pictures with letters next to parts I don't quite know. Fill in the blanks if you can.
BTW, this engine is a JDM d15b Vtec-e engine.
Each one of these is a sensor or wire of some sort, except for C, which is a tube that I don't know where it goes. I guess that could be the coolant line, but if it is, what is the tube under F?
D is an interesting one. It had two wires that go to the plug (green and black) and then four grounds that attach to the block. This might be the termostat housing, but it doesn't resemble the one I've seen from the d15b2, so it's all greek (or in this case, it's all Japanese) to me.
Is H the EGR? Is I the knock sensor?
Please help as I'd like to prepare for my swap with as much ease as possible.
Old Sep 14, 2005 | 08:48 PM
VRD^sam's Avatar
Default Re: Need help identifying wires, etc. (SiMateoAko)
buy a honda manual...
Old Sep 14, 2005 | 09:12 PM
SiMateoAko's Avatar
Default Re: Need help identifying wires, etc. (boosted_ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_ef &raquo;</TD></TR><TR><TD CLASS="quote">buy a honda manual...</TD></TR></TABLE>
Considering that it's 11pm and the stores are closed, I was counting on the kindness of strangers for this one.
Man, every time I think that this place is a community to help each other, some jerkoff goes and shatters that illusion.
Hey, remember when your mom told you that if you had nothing good to say that you'd be better saying nothing at all? Well, she wasn't just talking about your complexion.
Old Sep 14, 2005 | 09:18 PM
FlatlineEF9's Avatar
Not too sure about D, E, F, and G. C looks to me like just a coolant line. B is your coolant temp wire for your gauge cluster. A is the coolant temperature sensor for the ECU. H is your IACV or (idle air control valve) plug. I is your Intake Air Temp Sensor or IATS. Id replace the TPS and like the guy before me said, id buy a manual. For this engine, id recommend any civic with a SOHC VTEC engine. Happy hunting
Oh, And C should go back to your Heater Core i believe. Someone correct me if im wrong. The hose under F goes to your lower radiator. and the hose at the front goes to the upper. Good luck, hope your swap works out for you.
Old Sep 14, 2005 | 09:20 PM
RCautoworks's Avatar
I = Intake air vale
H= eletronic air control valve
B , and A look like coolant temp sensors. I know A is for sure
D = Radiator fan switch
Get some better pics
Old Sep 14, 2005 | 09:31 PM
SiMateoAko's Avatar
Default Re: Need help identifying wires, etc. (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Get some better pics</TD></TR></TABLE>
This is the only other one I have. I can get a close up of A and B tomorrow.
Old Sep 14, 2005 | 09:34 PM
Im 100% sure of the sensors that i told you about already. As well as the names and the acronyms for them as well.
Old Sep 15, 2005 | 06:48 AM
vtecn8ive's Avatar
Default Re: Need help identifying wires, etc. (FlatlineEF9)
A & B coolant temps
C heater core hose (should be outlet side I think)
D should be fan switch
E don't know
F don't know (may be vtec solenoid)
G not sure (may be oil pressure sensor)
H Idle Air Control Valve
I Intake Air Temp Sensor
And yah you'll need to fix your TPS
Old Sep 15, 2005 | 07:57 AM
SiMateoAko's Avatar
Default Re: Need help identifying wires, etc. (vtecn8ive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecn8ive &raquo;</TD></TR><TR><TD CLASS="quote">A & B coolant temps
E don't know
And yah you'll need to fix your TPS </TD></TR></TABLE>
Looks like I need to fix my IATS too. I guess this is when over planning really pays off. I have a whole set of extra sensors to use.
If A and B are both coolant temps, which one is ECU and which one is for the dash?
Old Sep 15, 2005 | 08:29 AM
vtecn8ive's Avatar
B for cluster
A for ecu
this is sourced from a post from FlatlineEF9
-Shane
Old Sep 15, 2005 | 09:21 AM
G= vtec solenoid
The ones next too it, I still can't tell where they run from the pics.
Old Sep 15, 2005 | 09:26 AM
vtecn8ive's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">G= vtec solenoid
The ones next too it, I still can't tell where they run from the pics.</TD></TR></TABLE>
Nope G is definately oil pressure its a threaded sensor.
F should be solenoid its the single green/yellow (i think) and it goes to the solenoid.
the only one I am not positve on is the 3 wire one(E). I am guessing that just has to do with the fact its a vtec-E.
A Coolant temp Ecu
B Coolant temp Cluster
E don't know ****probably has to due with vtec-E ****
F vtec solenoid
G oil pressure sensor
Old Sep 15, 2005 | 09:32 AM
A Coolant temp Ecu
F vtec solenoid
I really ment it was just for vtec, I did not look at it twice. Plus all this has been covered in the faq section
Old Sep 15, 2005 | 09:38 AM
vtecn8ive's Avatar
I really ment it was just for vtec, I did not look at it twice. Plus all this has been covered in the faq section</TD></TR></TABLE>
lol, yes it has. In fact some one had like the identical question. I kinda like how you have it though cause the other one was of the harness this one is of the places on the motor they go
GRN MCHN
May 26, 2013 10:40 PM
Maple50175
Honda Civic (2001 - 2005)
Nov 21, 2010 08:23 PM
lorenzookc
Jan 26, 2010 06:22 PM
scspeed
Aug 23, 2008 10:46 PM
stackz
Oct 2, 2006 05:42 AM
