Injector size w/ SKUNK2 PRO1?
for an LS/VTEC runing a set of Skunk2 PRO1 cams with P30 pistons (11.8:1) what injectors to use? im gonna see how high i can run my stock 240cc with uberdata. im gonna turn the fuel pressure up to around 60 psi so i can run the stockers
I run 11.5 B18c1 with stockers and BC3+ cams on Crome Pro with bumped up fuel pressure and it is nowhere close maxed out...
BC3+ take a lot of fuel around 6200, but there is still room in my case, in your case you'll need a touch more fuel up top with those cams, but motor has a tendency to need less fuel as rpm goes up past tq peak so I think that you shoud be ok...
Once you start crossing 200whp, you'll be pushing it, so something like headers can easily get you over...
Revs will get you. I haven't finished the Sk2Pro1 car I'm tuning, but I have little doubt that it will be making power into low 9000s... With that high of a redline, you need bigger injectors bad.
The BC3s in a GSR w/ P30 pistons and a portflow head maxed out stock injectors @ stock fuel pressure around 8400.
im only revving motor to around 8K-8.4K (Stock LS rods with ARP rod bolts)
well im gonna see how much i can get outta the stock injectors when i tune next week. but i highly doubt that the Duty cycle option in uberdata shows the correct values. did version 1.7 fix that problem or no?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar »</TD></TR><TR><TD CLASS="quote">Revs will get you. I haven't finished the Sk2Pro1 car I'm tuning, but I have little doubt that it will be making power into low 9000s... With that high of a redline, you need bigger injectors bad.
The BC3s in a GSR w/ P30 pistons and a portflow head maxed out stock injectors @ stock fuel pressure around 8400.</TD></TR></TABLE>
+1 vote.
8400rpms is about the limit. 310cc or H22 290cc with a FPR
+1 vote.
i'll see if i can get a hold of some 310cc's by next week. if i dont i'll just see how far i can run the stock injectors with the fuel pressure bumped up to give me a little bit more dutycycle
ncVTEC1313
Aug 24, 2008 06:34 PM
