civic type R compression
Old Sep 14, 2005 | 06:45 PM
ganjafarmer143's Avatar
Default civic type R compression
hey what is the stock compression on the civic type R (B16b engine)? and also if your compression goes to 12.5 to 1 do u have to use race gas? how true is this?
Old Sep 14, 2005 | 08:53 PM
RudeBwaiSi's Avatar
That CR I believe is 10.8:1. If you run a CR of 12.5:1, you could perhaps use at least 93 octane with a good tune. That is pushing the limits in my opinion still.
Old Sep 14, 2005 | 09:06 PM
2k.civic.si's Avatar
Default Re: (RudeBwaiSi)
i ran 12.7:1 on 91 with stock timing maps from a p30 ecu...this was with ctr cams so i know cylinder pressures were high due to low overlap as compared to aftermarket cams
Rushintegra
Apr 28, 2013 08:37 PM
djangel1343
Nov 14, 2007 12:30 PM
DC4R27
Feb 9, 2007 11:51 AM
jikespingleton
Nov 21, 2006 09:02 AM
Parker69
Jan 14, 2003 08:05 AM
