How fast is a z6 in a crx?
Old Sep 14, 2005 | 04:16 PM
dturbo's Avatar
Default How fast is a z6 in a crx?
planning on getting a crx from a buddy for a couple hundred bucks. thinking of doing a simple d16z6 swap into it for the time being since I got an extra laying in the garage. How quick would a stock z6 in a crx run on the 1/4 mile?
Old Sep 14, 2005 | 04:18 PM
b18cEF9's Avatar
Default Re: How fast is a z6 in a crx? (flyazzcivic)
better get a huge wing, your 1/4 mile time will be like 5 seconds, so youll need some downforce know one knows what your car will run with a z6 in it, 15's im geussing, maybe 16's depends on the car/driver/track conditions. so swap the motor and take it to the track and let us know how fast u ran
Old Sep 14, 2005 | 04:24 PM
shawn_crx's Avatar
Default Re: How fast is a z6 in a crx? (b18cEF9)
almost fast as a supra but slower than a turtle.
Old Sep 14, 2005 | 04:28 PM
dturbo's Avatar
I know its not going to be fast...i was wondering what the 1/4 mile times would be with a stock z6. Just wondering if it will be quicker then my buddies stock d15b in his hatch at 15.3.
Old Sep 14, 2005 | 04:31 PM
BDietrich84's Avatar
ha ha ha... weight, power and drag, you do the math.
Bench racing is for tools.
Old Sep 14, 2005 | 04:33 PM
Mach69's Avatar
There was a guy doing 14.1 in his crx hf with a d16z6 and bolt ons. Forgot his name though.
Old Sep 14, 2005 | 05:09 PM
91whiteZCrex's Avatar
Default Re: How fast is a z6 in a crx? (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">There was a guy doing 14.1 in his crx hf with a d16z6 and bolt ons. Forgot his name though.</TD></TR></TABLE>
true he had a zex cam tho also
Old Sep 14, 2005 | 05:35 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: How fast is a z6 in a crx? (91whiteZCrex)
between mid 9s and high 20s.
Old Sep 14, 2005 | 05:45 PM
ukdm crx's Avatar
Default Re: How fast is a z6 in a crx? (Ace$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper &raquo;</TD></TR><TR><TD CLASS="quote">between mid 9s and high 20s.</TD></TR></TABLE>
Old Sep 14, 2005 | 05:53 PM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">There was a guy doing 14.1 in his crx hf with a d16z6 and bolt ons. Forgot his name though.</TD></TR></TABLE>his name was Bserieskllr, his best was actually 14.0 in the 1/4
his mods were, i think this is all of them...
gutted HF
HX wheels, and i believe Azenis
d16z6 with head milled
b16 ecu
Exedy clutch
SI cable trans
he also ran a 13.6 on nitrous and spun 2 rod bearings halfway down the track, so he was letting out of the gas towards the end
Old Sep 14, 2005 | 06:32 PM
Mach69's Avatar
Default Re: How fast is a z6 in a crx? (ryan89crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx &raquo;</TD></TR><TR><TD CLASS="quote">b16 ecu
How the hell did he use a b16 ecu? Can I use one?
Old Sep 14, 2005 | 09:22 PM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">How the hell did he use a b16 ecu? Can I use one? </TD></TR></TABLE>yes, he used a b16 ecu..he had a solid CEL, i believe code 9, but he ran it anyways. more fuel...higher rev limit, its all good
Old Sep 14, 2005 | 10:08 PM
goforbroke's Avatar
MEAT PATTY
I knew someone was going to say BseriesKiller, his times are unheard of really. He just has the right combination and driver to produce a killer time. Don't set your expectations so high if your going to go off of his time.
Old Sep 15, 2005 | 05:54 AM
driveahonda's Avatar
stock z6.. between 15.00 - 16.50.. all depends on driver/tires/clutch
Old Sep 15, 2005 | 06:23 AM
CRX90ZCT's Avatar
15's
Old Sep 15, 2005 | 04:31 PM
ryan89crx's Avatar
well my stock a6 with centerforce stage 2 clutch and SI tranny ran mid 15s in my crx. so id figure a motor making 22 more hp would hit that fast as well
Old Sep 15, 2005 | 04:40 PM
91 crx savage's Avatar
enough to beat a b16
Old Sep 15, 2005 | 05:01 PM
Vinceg99's Avatar
Default Re: (91 crx savage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91 crx savage &raquo;</TD></TR><TR><TD CLASS="quote">enough to beat a b16 </TD></TR></TABLE>
Is that a question or a statement?? cause no a stock Z6 wont beat a B16.
Also dont get a Z6 thinking its going to be way faster than an A6. I stayed even with my brother in-laws z6 swapped 91 hatch and I have a 91 CRX with an A6 and he did his swap the right way, obd-0 to obd-1 swap and the p28 ecu so no msd switch or anything...
Old Sep 15, 2005 | 05:32 PM
ryan89crx's Avatar
Default Re: (Vinceg99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinceg99 &raquo;</TD></TR><TR><TD CLASS="quote">Is that a question or a statement?? cause no a stock Z6 wont beat a B16.
Also dont get a Z6 thinking its going to be way faster than an A6. I stayed even with my brother in-laws z6 swapped 91 hatch and I have a 91 CRX with an A6 and he did his swap the right way, obd-0 to obd-1 swap and the p28 ecu so no msd switch or anything...</TD></TR></TABLE>hatch compared to CRX = about 200lbs...
Old Sep 15, 2005 | 05:33 PM
SiR Inspired ED7's Avatar
high 15's
Old Sep 15, 2005 | 05:53 PM
goforbroke's Avatar
MEAT PATTY
Default Re: (ryan89crx)
You won't drop 1.5 seconds in 1/4 with only 22 more hp, come on fellows lets be realistic about this. You won't even drop a second with that much power. I mentioned it before don't set your expectations so high you will be let down.
Old Sep 15, 2005 | 05:55 PM
88 rex's Avatar
Default Re: (goforbroke)
about 15.0
Just a guess
Old Sep 15, 2005 | 06:00 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
well as i said before, my bros car, an 88dx on bald 13s was hitting 15.3s with an mpfi swap an si tranny. we put in a y7block/y8 head deal and got it to go 14.7s. pretty impressive for a stock sohc on bald 13s. this was with the timing advanced all the way, and running a pg7 ecu.
Old Sep 15, 2005 | 06:27 PM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx &raquo;</TD></TR><TR><TD CLASS="quote">hatch compared to CRX = about 200lbs...</TD></TR></TABLE>
Actually since his is a std and mine is a dx there is only like 70 or so lbs difference and he has rear drum and i have rear disc which makes mine heavier I also have sway bars and he doesnt plus strut bars and he doesnt so technically they are pretty compariable in weights....
*EDIT* According to this my CRX is only like 24lbs lighter than his std Hatch and I make up for that in sway bars, suspension, and rear discs...http://autos.msn.com/research/...sub=4
rcboy2793
Aug 29, 2010 05:30 PM
whitehf
May 12, 2005 11:07 AM
demon_hatch
Jul 15, 2003 03:06 AM
pdiddyparsons
Nov 13, 2002 02:08 PM
