Whats needed to install a header??
Old Sep 14, 2005 | 02:10 PM
Project_EK's Avatar
Default Whats needed to install a header??
what up,
I bought a d16y8 header for dirt cheap (to replace the crappy y7 header) anyway do i need to buy a new gasket or anything when installin it? and do the bolts need to be torq spec'd? thanks
also, has anyone ever taken off a stock header by hand?? i heard they can be a PITA!!!
Old Sep 14, 2005 | 02:21 PM
BlueIntegraBoy's Avatar
Default Re: Whats needed to install a header?? (EKhatch219)
Installing a header isn't hard. You need simple wrenches and sockets, as well as jack + stands. You will need to buy a new exhaust manifold gasket and you can reuse your donut gasket. It is highly recommended you torque the bolts especially on the head.
Old Sep 14, 2005 | 02:26 PM
Civicse's Avatar
Default Re: Whats needed to install a header?? (BlueIntegraBoy)
if its going on a y7 engine then u;'ll have to relocate the cat under the car, u'll need an ex cat, and an o2 wire extension, little bit more work
pdevilk
Mar 11, 2012 05:07 PM
sixtodc2
Mar 13, 2006 05:37 AM
00CivicSleeper
11
Mar 24, 2005 04:02 PM
98vsmferio
13
Dec 29, 2004 03:09 PM
Loveless
Jul 29, 2003 08:41 PM
