what parts can be for auto and manual
well i have a 1992 CX hatchback and want an LS swap. my friends friend just had his LS hit and it was deemed totalled. my question is this: the LS that was hit was an Automatic the swap im gettin is Manual...can i take the dizzy, alternator and starter from the totalled car and it still work the same.
because its an automatic. i thought an auto engine couldnt fit on a manual trans.
the question was im gettin a 1995 integra LS swap for my 1992 hatchback. can a distributor, alternator, starter from a 1998 automatic LS work on a 1995 integra LS
But will these parts work on the 1995 LS comin from a 98. are you 100 percent sure that the trans can just be switched? wouldnt the trans to engine bolts be different. like not align to each other.
All bseries transmissions are the same im 100% sure all you need to do is change the transmission. you can use any b16, gsr, or ls hydraulic transmission..
sleepyhamsterlx
13
Mar 17, 2003 08:21 AM
